Need to create adequate drain to place at base of a cmu retaining wall that is built on a stepped concrete footer (retaining wall slopes down a hill). Can I simply place 3" Drilled PVC at the base across each concrete step and backfill with gravel and landscape fabric, or do I need to create a "stepped" drain pipe (envisioning elbows at each step in the concrete)?
First off it should be engineered if it is a retaining wall.
We use 4" weeping pipe with a sock and use 45's not 90's at the steps.
We place the landscape cloth on the cut of the bank, start filling with gravel. If the wall exceeds 5' high I will run another weeper about halfway up....cheap insurance and helps keep the pressure off the wall.
We do the same except we dont use a sock only landscape fabric as a barrier between the rock and soil
Related Threads
3.5M posts
151.3K members
Since 2003
