Do You Need A Permit For A Retaining Wall?
Old 12-14-2007, 09:11 PM   #1
KAT_Ayanami's Avatar
Trade: Masonry
The retaining wall is 5' tall and will be on the side of the house dividing two properties that are unleveled. (retaining wall will be on both owners yard).
Do you need a permit?
Work is in Rockville, MD.
Thanks.
KAT_Ayanami is offline
Old 12-14-2007, 09:24 PM   #2
concretemasonry's Avatar
Trade: Masonry consultant
Re: Do You Need A Permit For A Retaining Wall?
Depending on the locality, the dividing line between permit/engineered designs is usually between 3.5' and 6', depending on the climate and local soil types.
Since this is on a property line, make sure you find out if a permit or engineered design is necessary. You could be leaving yourself wide open in the future.
For such a short wall, a segmental block retaining wall (not requiring footings) may br more practical than a rigid concrete or reinforced block retaining wall that does require spread footings.
Your local city engineer may have standard design plates for these type of walls since they are commonly used with street widening projects and new sidewalk construction. If not, some of the sites for national segmental retaining wall unit suppliers (Allan Block, Anchor Wall Systems, Keystone or VersaLok) may offer some ideas and design guides.
Dick
concretemasonry is offline
Old 01-04-2008, 10:17 AM   #3
sunshineturf's Avatar
Trade: Landscape design and maintenence
in mass we have to pull a permit for any structure over 48 inches. Hope it helps
sunshineturf is offline
Old 01-04-2008, 05:52 PM   #4
PSDF350's Avatar
In Mass you need to pull a permit to fart. Thats why I no longer live there.
PSDF350 is offline
Old 01-04-2008, 06:30 PM   #5
Must be a policy or effort to make the air polluters leave the state.
Dick
Old 01-04-2008, 06:48 PM   #6
Professional Instigator
rbsremodeling's Avatar
Yes
WHEN IS A FENCE / RETAINING WALL PERMIT REQUIRED?
A permit is required to install any type of fence or retaining wall over 30" in height.
EXCEPTION:
When an existing fence that was INSTALLED WITH A BUILDING PERMIT is being replaced with the same kind of fence in the same location at the same height, no permit is required.
WHAT IS THE PURPOSE OF THIS PERMIT?
The purpose of the permit is to determine whether or not the zoning setback requirements for the location and height of the fence / retaining wall have been met.
WHAT ARE THE FEES?
  • Fence = $36.00
  • Retaining wall = $150.00
An additional 10% Automation Enhancement Fee is charged on the cost(s) listed above.
WHAT ARE THE REQUIREMENTS FOR THIS PERMIT?
  • Completed building permit wall application
  • Two (2) copies of the site plan showing the fence/wall location
  • For retaining walls, two (2) sets of construction drawings
Conditions of Approval: The fence height may not exceed six and one-half feet (6'-6") measured from the lowest level of the ground immediately under the fence/retaining wall. On a corner lot, for a linear distance of fifteen (15') feet from the intersection, the fence height may not exceed three (3') feet above curb level. Occasionally, lot conditions require approvals from other agencies:
  • M-NCPPC
  • Easement holders
  • Homeowner's associations
WHAT HAPPENS IF THE PERMIT IS DENIED?
An appeal may be made to the Board of Appeals. Department of Permitting Services zoning staff can help file an appeal.
WHEN WILL THE PERMIT BE ISSUED?
If all requirements are met, the permit can be issued on the day of application.
PERMIT DURATION:
The permit is valid for one (1) year from the date of issuance. One six-month extension may be applied for prior to permit expiration. For further information contact (240) 777-6370.
rbsremodeling is offline
Old 01-04-2008, 06:57 PM   #7
bujaly's Avatar
Trade: Commercial interior super
Originally Posted by rbsremodeling View Post
Yes
EXCEPTION:
WHAT ARE THE FEES?
  • Fence = $36.00
  • M-NCPPC
  • Easement holders
PERMIT DURATION:
Hey. Did you copy and paste this or jott it all down?
"Relentless in Reliability and Satisfaction!"
Oh yeah, 1 other thing...
Assuming doesn't make an a55 out of me and you, it makes an a55 out of YOU and YOU!!!
bujaly is offline
Old 01-04-2008, 08:18 PM   #8
It is a note/sticky from my arsenal of information to give people who asks questions about permit of requirements
Old 01-04-2008, 08:36 PM   #9
The preceding applies only to one metro area and for replacement of existing. Many of the sections apply to zoning and fences that are much different in other areas.
Most others have a 4' limit without any engineering. Some do not require a permit for less than 4'. Fences have signifigantly different requirements than retaining walls.
It is best to check with your local code AND zoning authority.
Dick
Old 01-04-2008, 08:44 PM   #10
Sorry thought he said he was in rockville, MD
Old 01-04-2008, 09:00 PM   #11
Remodeling GC
kevjob's Avatar
Thanks.
check with building dept and good idea to have it signed off by third party especially when dealing with adjoining propertys.
kevjob is offline
Old 01-04-2008, 09:37 PM   #12
General Contracting
LNG24's Avatar
Trade: Real Estate Broker, Property Manager
He did and your post was therefore relevant. To ask all of us if he needs a permit, well I am not sure he should be doing the work then.
To the OP:
In the future, if you want to know if you need a permit. You check with the town and county you are working in. Not Here!
Because if I tell you you don't need a permit, because in My Town you don't and YOU DO in YOUR TOWN, What good is my information to you then.
A simple phone call to your local building department shall tell you exactly what you need.
LNG24 is offline
Old 01-04-2008, 10:40 PM   #13
ruskent's Avatar
Trade: Outdoor D/B
If you are the lucky the town will issue the permit in less then 7 weeks!! Boy do i love dealing with towns.
ruskent is offline
Old 01-07-2008, 08:33 AM   #14
glad you clarified why you left mass. Hope you feel better having got that off your chest. But that aside to the guy we are trying to help here check your local laws. Dont ever guess, we can give all our location specific help but you have to check locally for you. I check every time since some of the neighborhoods we work in are very competitive and 90% of the time a neighbor calls the town anyway.
Old 01-07-2008, 12:04 PM   #15
PSDF350's Avatar
Glad to see no one has a sense of humor.
PSDF350 is offline
Old 01-07-2008, 02:06 PM   #16
a sense of humor can be easily mistaken over the internet given we cant sense sacasm etc. With no prior relationship your comment seemed out of context. No harm done I just am on this site for business.
Old 01-07-2008, 04:21 PM   #17
dirt diggler's Avatar
Trade: contractor
Thanks.
i just have to ask you
how the F**K are WE supposed to know???
are we supposed to have like access to every locality's building permit information in the country???
what makes you think any of us would know better than the ... hmmm - the city or town that you're in????
I mean - just don't get your mentality here. It's like asking us
"hey guys - does the gas station down the street from me take credit cards??"
and why would you trust someone's answer to begin with?? What if there is information missing ???
if you're just tryin to start conversation, that's one thing. I just don't understand the mentality.
God, I hope to God that you're a homeowner and not the contractor- I really do.
Thanks in advance!!!
dirt diggler is offline
Old 01-08-2008, 10:57 PM   #18
PSDF350's Avatar
I'm sorry but if you can't tell thats humor... (well half humor any way). But come on like dirt diggler said, how can any of us help him with permits or codes. Lets be real here i'm in NH your in I don't know, but maybe with your name I might think FLA, he's in MD. So how is anything any of us tell him relavent. Now if he asked how to build said wall that might be differant.
PSDF350 is offline
Old 01-09-2008, 12:07 AM   #19
bujaly's Avatar
Well, then the question begs... Can I build a home here on my street and how much should I charge myself?
bujaly is offline
Old 01-09-2008, 07:06 AM   #20
PSDF350's Avatar
PSDF350 is offline
Retaining wall costs? Cherryhill_cons Landscaping 12 11-11-2007 12:29 PM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 11:27 PM
Building Blocks for Retaining Wall robertc65 Landscaping 2 04-25-2007 03:53 PM
Retaining Wall LNG24 Masonry 3 02-17-2007 12:53 PM
Retaining Wall Hockeyman Landscaping 7 09-21-2006 12:00 AM
