Cutting Railroad Ties
Old 12-12-2012, 07:24 AM   #1
Spike7's Avatar
Trade: interior/exterior
Rewards Points: 402
client wants me to replace 15 or 20 of these , they come 12 feet in length
whats the best way to cut them if i need to ?
best power tool for this?
i looked it up on utube ,. there was no talking , just a video of the guy cutting through a tie, and it looked like it took him 3 or 4 minutes , and it looked tough.
he was wearing one of those throw away painters over-alls , full face mask and goggles and gloves
it showed him using a gas-powered stihl saw( possibly a 14 inch) . but it didn`t show what type of blade he was using .
any info would be appreciatted
Spike7 is offline
Old 12-12-2012, 08:22 AM   #2
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 628
Re: Cutting Railroad Ties
Chainsaw is the easiest. I am sure they have something in them that will give you cancer. I've cut hundreds and still cancer free A mask if your worried about it, I'm not.
I can't compete with hacks.
donerightwyo is offline
Old 12-12-2012, 08:26 AM   #3
Rewards Points: 628
I found the you tube video
They are just wood. That looks really dangerous, and time consuming.
Old 12-12-2012, 08:29 AM   #4
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,168
Send a message via MSN to KennMacMoragh
Yup chainsaw, get out a framing square and red lumber crayon if you want to make accurate cuts. Watch out if you're cutting just a little bit off one end, sometimes there are metal plates put into the ends of these which you don't want to cut through. It's heavily treated wood so a dust mask is a good idea, but you are cutting below you so you shouldn't be breathing in a lot of dust.
kenparsonscontracting.com
KennMacMoragh is offline
The Following User Says Thank You to KennMacMoragh For This Useful Post:
hdavis (12-12-2012)
Old 12-12-2012, 08:33 AM   #5
Interesting, it looks like he can make a pretty smooth cut with that cutoff saw, smoother than you can get with a chainsaw. But a chainsaw with a new chain will cut through it a lot faster.
+ YouTube Video
Old 12-12-2012, 04:06 PM   #6
hdavis's Avatar
Rewards Points: 7,115
You can get a smooth enough cut with a chainsaw as long as the chain is tight and the bar isn't worn too much. Also, I prefer a longer bar when cutting - it's easier to get lined up to your cut lines. I'd definately check for metal before cutting, you can never tell where there might be something.
hdavis is online now
skcolo (12-27-2012)
Old 12-12-2012, 05:52 PM   #7
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
real r/r ties are very abrasive and chains need sharpening often
Tom Struble is offline
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
donerightwyo (12-12-2012), SAW.co (12-15-2012)
Old 12-12-2012, 06:11 PM   #8
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
I will never forget about the time I thought I could cut a telephone pole with a chainsaw. How do they get that rebar in there anyways..
ohiohomedoctor is offline
The Following 2 Users Say Thank You to ohiohomedoctor For This Useful Post:
donerightwyo (12-12-2012), hdavis (12-12-2012)
Old 12-12-2012, 10:12 PM   #9
Spike7's Avatar
Rewards Points: 402
thanks guys
just never did it.
Spike7 is offline
Old 12-13-2012, 03:39 PM   #10
Thom
thom's Avatar
Rewards Points: 4,748
Chain saw is slow, chain gets worn very quickly.
The very fastest way is with a demolition saw and a carbide blade.
You will need to flip the tie over and cut from both sides. you will get a much better cut, much faster, and not need to sharpen the chain after each tie.
I've done it both ways, the demolition saw wins this in a run away.
Patriotism is being loyal to your country all the time and your government when it deserves it. Mark Twain
thom is offline
The Following User Says Thank You to thom For This Useful Post:
hdavis (12-13-2012)
Old 12-13-2012, 07:42 PM   #11
President
CarrPainting's Avatar
Trade: Residential Repaints
Rewards Points: 1,316
how bout a sawzall... whatever you do, dont burn any!
Originally Posted by Easy Gibson View Post
Explain like I'm five. Thanks.
CarrPainting is offline
Old 12-13-2012, 07:57 PM   #12
Nest Home Improvement
carolinahandyma's Avatar
Trade: Home improvement simplified!
Rewards Points: 518
For health concerns with RR ties check out http://waterquality.montana.edu/docs...wq_faq_3.shtml
Serving the home improvement needs of the Triangle www.NestHomeImprovement.com
carolinahandyma is offline
Old 12-13-2012, 09:13 PM   #13
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 178
Did a whole day of those with my crew for my son's Montessori school.
We just hit them top and bottom with the worm drive at full depth then finished with a sawzall and shorter/stiffer, carbide-tipped blade. Sawzall rode the deep cuts smooth and easy. We had to do miters on every one.....and fast....cause it was fo free. We beveled the edges with a power planer for anti-face scarring on falling 4yr olds.
BlueRidgeGreen is offline
Old 12-13-2012, 09:20 PM   #14
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
There was this one time........got really drunk.......had a couple rail road ties.............had a fire................all day.........after.
CrpntrFrk is offline
The Following 2 Users Say Thank You to CrpntrFrk For This Useful Post:
Acres (12-17-2012), TNM (01-15-2013)
Old 12-13-2012, 10:18 PM   #15
wyoming 1's Avatar
Trade: General contractor
Rewards Points: 520
We have done a bunch with a chain saw. Its not too bad look for spikes, metal and rocks before you cut and I would recommend a full chisel chain.
wyoming 1 is offline
Old 12-15-2012, 01:11 AM   #16
SC sawdaddy's Avatar
Rewards Points: 1,018
You dont want to get that creosote sawdust down your pants.
No, you cant hold my hammer. Where is yours?
SC sawdaddy is offline
The Following User Says Thank You to SC sawdaddy For This Useful Post:
CrpntrFrk (12-15-2012)
Old 12-15-2012, 07:48 PM   #17
Jdub2083's Avatar
Trade: General Contracting / Commercial Carpenter
Rewards Points: 282
I remember a few years ago my dad milled up some telephone poles on his sawmill and the creosote gave him some sort of chemical burns on his arms. Pretty nasty stuff.
Jdub2083 is offline
The Following User Says Thank You to Jdub2083 For This Useful Post:
Acres (12-17-2012)
Old 12-15-2012, 08:10 PM   #18
TRADE CRAFTSMAN.
SAW.co's Avatar
Trade: general contractor
I've cut many R/R ties with a chainsaw.
Ya they dull fast but never put too much thought into making super clean cuts.
After we are talking R/R tie's.
I,ve never used them for anything but a retaining wall or garden steps.
SAW.co is offline
Old 12-17-2012, 10:20 PM   #19
Acres's Avatar
Trade: lawn maintenance
Rewards Points: 250
What's it for?.. Try talking him out of it..There just gonna rot again anyways.. stone, stone, stone... PS I love when the ties start rotting and then bees/yellow/wasps slide in there.. they all come out to greet me..
Acres is offline
Old 12-18-2012, 12:13 AM   #20
Dirtywhiteboy's Avatar
Rewards Points: 7,958
16inch beam saw
Dirtywhiteboy is online now
Gary H (12-19-2012)
Made in USA product list J.C. General Discussion 351 04-15-2018 09:39 PM
Bought a new Ridgid tile saw...any reviews here? IHI Tiling 45 11-24-2012 12:03 PM
cutting multiple precise plumb slots in rafter peakecg Finish Carpentry 15 08-17-2012 11:08 AM
Railroad Ties ckobesko Landscaping 3 05-18-2009 09:22 PM
Determining Manhours for rolling vs. cutting - your suggestions would be helpful Zeebo Painting & Finish Work 9 06-02-2006 05:12 PM
