Cutting Grass
what is the afect on my grass if I cut it tall 3" or if I cutt it shorter? how does either affect the roots and blades. or the difference in denseness or being sparse? help and thank you much.
Re: Cutting Grass
I would say that it all depends on the type of grass. Here, we cut Floratam to one height and Bermuda to another.
Re: Cutting Grass
I have a book authored by the late James Underwood Crockett, a well known horticulturist, which has the recommendations on cutting height and other chores in the maintenance of lawns and groundcovers. Normally, the cutting height is determined on temperature, type of grass and the moisture in the ground. For Kentucky bluegrass, the cutting height is 2 to 2-1/2 inches in Spring and early Summer. When soil temperatures reached 80 degrees, the grass becomes semidormant and does not grow as fast or robust as in Spring. In hot weather, 3 inches is recommended. If you list what type of grass you have and where you live, I'll check my book for the recommendations.
| Handyman getting into grass cutting | 2500hd | Landscaping | 53 | 10-24-2009 07:45 PM |
| A B C slot cutting for recompaction. | MC Excavating | Excavation & Site Work | 17 | 03-13-2007 07:04 AM |
| proper way of loading of brush from a cutting pail | Zeebo | Painting & Finish Work | 7 | 08-11-2006 11:58 PM |
| Cutting steel roofing-what do ya'll use | IHI | Roofing | 9 | 07-02-2006 07:41 PM |
| Determining Manhours for rolling vs. cutting - your suggestions would be helpful | Zeebo | Painting & Finish Work | 9 | 06-02-2006 06:12 PM |
