Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Landscaping
Old 01-18-2009, 03:38 PM   #1
Carpenter
woodbutchr's Avatar
Chain Link Tips
I got about 150' of Chain Link to install in a couple weeks. I've never done Chain Link before. Do y'all have any tips or tricks that make it faster & easier? Other than the obvious.
Can I use a T-post driver to drive in the line posts?
woodbutchr is offline   Reply With Quote
Old 01-18-2009, 04:25 PM   #2
Crash Test Dummy
ChainsawCharlie's Avatar
Trade: Landscaping
I would auger the holes and set the posts in concrete, myself.
ChainsawCharlie is online now   Reply With Quote
Old 01-18-2009, 04:32 PM   #3
Make a V with the handles of
the postholers, stick one through
near the top, one near the bottom
use the post as a fulcrum to stretch
the fabric.
Everything else I've purposely
forgotten.
neolitic is offline   Reply With Quote
Old 01-18-2009, 04:40 PM   #4
Sean
SLSTech's Avatar
You can use a driver - but you need to put a cap/adapter on it, or you will damage the top & never get the railing caps on it without cutting the posts
Also the first & last one must be in concrete along with a few in the run & any corners, but I agree with CC & do them all
SLSTech is offline   Reply With Quote
Old 01-18-2009, 04:59 PM   #5
Carpenter
woodbutchr's Avatar
the fabric.
forgotten.
I like that idea but I was just gonna buy me one of the stretcher things for $30 bucks. That way I'll have it if I do any more later down the road.
I was thinkin' bout setting the end posts & then bracing them off so I can pull my lines without waiting for the concrete to set up??? (Just like setting up corner poles for layin' brick)
If I pull it tight enough, do I need tension wire for the bottom?
I reckon I'll price it by the ft.
Thanks y'all
Old 02-10-2009, 06:32 PM   #6
all in concrete...
if you have a tractor with a front end loader, it makes an awesome fence stretcher, just make sure you're pulling in a parellel line and verrrry slowly.
72chevy4x4 is offline   Reply With Quote
Old 02-10-2009, 06:42 PM   #7
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
to stretch it you can use a come-along. You can also attach a chain to your truck hitch if you do not have a front end loader sitting around waiting to be used.
Norman Sharp
http://www.sharpimprovements.com
Norrrrrrrrrrrrm is offline   Reply With Quote
Chain Link Fence Painting - Material??? NAV Painting & Finish Work 13 12-08-2008 10:23 PM
price check on 8' chain link 72chevy4x4 Decks & Fencing 0 09-02-2008 06:39 AM
Who knows about chain link fences? Greg Di Decks & Fencing 17 06-19-2008 08:42 AM
Installing chain link line posts Tim C. Decks & Fencing 10 01-06-2008 04:24 PM
chain link fence Alkyd Painting & Finish Work 10 03-09-2006 08:42 AM
