Bridge Work
Old 03-11-2009, 09:13 PM   #1
KGB's Avatar
Trade: CARPENTER CONTRACTOR
Bridge Work
Looking for a little info.
have customer who needs small bridge fixed that goes over a small creek.
small size 8' long by 10' wide .
existing now has 15 8" x 8" - 8' long railroad ties over this span.
are rail road ties oak or some other wood.
I was going to replace with oak not treated 8 x 8 .
treated is yellow pine and i know there not strong enough for that use.
has any one ever come across this in the past.
thank you
KGB is offline
Old 03-11-2009, 11:18 PM   #2
72chevy4x4's Avatar
Re: Bridge Work
does he drive a tractor across the bridge? the weight load traversing the bridge will impact the type of materials (and footing) used. It's easy to cobble something together when your a HO, but when a contractor does it with his(her) name and insurance on the line, you've got to make sure it's right.
you might try rereading your post-the grammer is off and makes it a little difficult to understand.
consider to steel I beams then cover with wood-if 'cheap' is the objective, then railroad ties sound about right.
72chevy4x4 is offline
The Following User Says Thank You to 72chevy4x4 For This Useful Post:
KGB (03-12-2009)
Old 03-12-2009, 12:51 AM   #3
KGB's Avatar
Re: Bridge Work
Yes you are right ,i am not a bridge builder i would take it to an engineer to have it spec before the installation of any work .
I was just to see if any one has ever come across some thing like this .
my answer will come from engineer.
KGB is offline
Old 03-12-2009, 10:44 AM   #4
KGB's Avatar
Re: Bridge Work
Look at job for second time . I look at it first time about 4 months ago . second look always look worse .
Job has to go to engineer . Needs new foundation for work to be done right . Existing foundation is two rows 8" block and sagging.
Thread closed thanks
KGB is offline
extra work questions for the pros A.W.Davis Business 27 01-03-2012 04:14 PM
taking a crack at my own concrete work J-Peffer Masonry 9 10-25-2010 06:16 PM
Do you believe the customer is always right? Mike Finley Business 43 06-17-2009 09:55 AM
What is a fair fee to pay for work? John Letterman Marketing & Sales 6 08-07-2008 11:08 AM
In answer to a closed thread. AAPaint donb1959 Painting & Finish Work 42 08-27-2006 01:36 AM
