Brick Saw
Old 10-06-2007, 08:44 PM   #1
Landscape Foreman
Chris Comeau's Avatar
Trade: Landscaping
Brick Saw
Hey all my concrete saw that I use to cut retaining wall stone keeps kicking the breaker at the houses that I use it at. I use a short heavy duty extension cord but for some reason it keeps doing that. Can I hook a power strip with a reset switch up so that it will kick that instead or something? I hate to have to call the homeowner every time and have them come flip the switch!!! Any advice?
Chris Comeau is offline
Old 10-06-2007, 08:50 PM   #2
Tscarborough's Avatar
Re: Brick Saw
It should be 10 gauge and no more than 50' for a 110v 14" saw, and 10 Gauge 25', 220v for a 20" saw. You may also be bogging the saw with excess pressure.
Tscarborough is offline
Old 10-09-2007, 10:20 PM   #3
Landscape Foreman
Trade: Landscaping
Re: Brick Saw
Thanks for the comment but I am pretty experienced with this kind of thing and I have always followed those guidelines closely. I was hoping there was some other solution to the problem than having the "DIY" electrician homeowner come home every five minutes to switch the breaker for me.
Old 10-09-2007, 11:26 PM   #4
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Brick Saw
Use a gas powered saw!!
Chris
Chris Johnson is offline
Old 10-09-2007, 11:32 PM   #5
Re: Brick Saw
If you are following those guidelines, then obviously the breaker is not sufficent to carry the load. There is no way around that, other than using a different circuit.
Old 10-10-2007, 01:19 AM   #6
MFWIC
Tmrrptr's Avatar
Trade: house painter
Re: Brick Saw
My target saw takes real good juice...
If I can, I put my own breaker in the box and dangle the cord out, which is probably in violation of alll kinds of rules and such.
Circuit you are using may already have some load on it, or a weak breaker.
Try the shortest 10g cord that will reach the laundry room, if it uses a 20a dedicated breaker for the appliances.
r
Tmrrptr is offline
Old 10-10-2007, 09:23 PM   #7
Landscape Foreman
Trade: Landscaping
Re: Brick Saw
My saw needs a 20 amp breaker but the guy that owns this house says he has 12 amp and there are also lights and things on in the house DIY electrician homeowner. Also each outdoor plug is on a different circuit so he has just wired into the houses circuits and used some juice from what operates inside. I am glad I am almost done with this guy!!
Old 10-11-2007, 04:48 PM   #8
tkle's Avatar
Re: Brick Saw
Can you run your saw on 220?Plug into the dryer outlet.
tkle is offline
Old 10-11-2007, 09:22 PM   #9
tgeb's Avatar
Re: Brick Saw
You could always supply your own power with a generator.
It would be cheaper than a gas engine powered saw, since you already have the electric saw.
Use the outlet on the house til you kill the breaker, switch to the generator to finish the job.
When the HO gets home tell 'em the breaker tripped, collect your check and move on.
www.gebcon.com
tgeb is online now
Old 10-11-2007, 09:58 PM   #10
Landscape Foreman
Trade: Landscaping
Re: Brick Saw
LOL I guess I will tell the boss on monday that I need him to go out and drop some cash on a generator.
Old 08-22-2008, 10:03 PM   #11
CJKarl's Avatar
Trade: Masonry
Re: Brick Saw
Could also be a GFI circuit. If you are using water with the saw, you may have a grounding problem.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 03-17-2009, 11:59 PM   #12
woodstone's Avatar
Trade: Outdoor Construction
Re: Brick Saw
Go with a gas saw. Won't cost a ton more than a good generator and will solve all your issues.
woodstone is offline
Old 03-18-2009, 02:10 AM   #13
Stewy's Avatar
Trade: home improvements and renovations
Re: Brick Saw
Gas saw would be great and cost a few bucks, you need a min. of a 20 amp circuit(like you said) and i have worked at new houses with no 20 amp outlets. I have had good luck plugging into a 115 outlet on a stove if one is available but the new stoves dont seem to have 115 outlets built in anymore.
Stewy is offline
Old 03-27-2011, 05:04 PM   #14
gevensen's Avatar
Trade: JRDM Construction NYC any remodelling/repairs
Re: Brick Saw
you can make a 110 adapter off the 220 dryer outlet then you have a 30a line
buy a dryer 220 cord 4x4 box and 110 out let and cover
just dont put l1 and l2 on the 110 outlet l1 and neutral
maybe kinda illegal
gevensen is offline
Old 03-27-2011, 05:23 PM   #15
Brickie's Avatar
Trade: One on top of Two
Re: Brick Saw
You can buy a nice used gas saw on craigs list for $200-$400:
http://chicago.craigslist.org/nwc/tls/2279999812.html
http://chicago.craigslist.org/sox/tls/2284189421.html
“Ron Paul is one of the outstanding leaders fighting for a stronger national defense. As a former Air Force officer, he knows well the needs of our armed forces, and he always puts them first. We need to keep him fighting for our country.” – Ronald Reagan
Brickie is offline
The Following User Says Thank You to Brickie For This Useful Post:
dakzaag (03-27-2011)
Old 03-27-2011, 09:15 PM   #16
Diamond D.'s Avatar
Trade: masonry/hardscaping
Re: Brick Saw
My guess is, that by now, the OP's boss, either bought a generator, a new gas saw or maybe he just went out of busness.
My .02, D.
" ROCK YOUR WORLD "
Diamond D. is offline
The Following User Says Thank You to Diamond D. For This Useful Post:
tgeb (03-28-2011)
Old 03-28-2011, 12:46 AM   #17
GC
NICKPAUS's Avatar
Re: Brick Saw
Old post but had same problem. Even my generator wont fire 220 brick saw. Here is the solution.
NICKPAUS is offline
Old 03-28-2011, 09:21 AM   #18
natural1's Avatar
Trade: Landscape contractor
Re: Brick Saw
I use either the gas saw shown above but more often a 14" concrete saw. The table saw is a beast with a honda engine that starts every time. It's a pain to lug around so the 14" stihl saw gets used the most.
Mike
http://www.natural-designs.com
natural1 is offline
Old 03-29-2011, 04:48 PM   #19
LauneLandscapes's Avatar
Trade: Landscaping & Decking Contractor
Re: Brick Saw
That looked like a lovely lawn until you ruined it with concrete dust...lol!
http://www.launelandscapes.com
LauneLandscapes is offline
Thin Brick, VS Regular Brick Project53 Construction 25 03-11-2010 03:13 PM
Braking metal for a brick exterior? Luke's Dad Windows, Siding and Doors 8 01-07-2007 06:59 AM
wire behind brick hurricaneflyer Electrical 7 11-13-2006 08:03 PM
red brick has developed a white coating wbsbadboy Masonry 4 02-28-2006 09:33 PM
