Bluestone Dust Vs Sand Under Flagstone - Landscaping - Contractor Talk
Old 06-23-2010, 09:51 PM   #1
DCRehab's Avatar
Trade: Renovations
I am planning a flagstone patio. Im located in MD, winters get cold and summers are hot and humid. I need to cover 550 sq ft with 1 1/2" Pennsylvania flagstone and I was planning on putting it on sand. I went to Irwin Stone and and someone recommended that I use Bluestone Dust instead of the sand. Does anyone have any thoughts on this? thanks in advance
DCRehab is offline
Old 09-23-2010, 05:06 PM   #2
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 242
Re: Bluestone Dust Vs Sand Under Flagstone
Stone dust and sand is just like icing on a cake. Both are good, but too much will ruin everything.
The key, no matter which you choose, is to make sure you have no more than 1 inch of sand as your final screed. 3/4" or less is even better. All the work under the patio is done by the crusher run, and the last tiny bit of sand is to help everything blend just right.
I would say use whichever is cheaper, concrete sand around here is more available and cheaper than stone dust.
NYCB is offline
The Following User Says Thank You to NYCB For This Useful Post:
CO762 (10-12-2010)
Old 10-12-2010, 07:46 PM   #3
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Heck, I'll thank you for that response to the OP.......
CO762 is offline
Mortar Sticking to Bluestone fakie99 Masonry 13 03-03-2011 10:10 PM
Table saw dust extraction roadweiry Tools & Equipment 15 05-23-2010 10:44 PM
dust in clear coat Traditions2 Painting & Finish Work 7 02-25-2010 08:36 AM
Flagstone over slab paulbronson Flooring 2 10-26-2009 07:15 PM
Lylac bluestone adhesion problems mcgyverdc Masonry 5 08-02-2009 05:02 AM
