EdenScapes
Trade: PAINTER,LANDSCAPER
Blade Clutch Quits When Hot
I own a Snapper pro hydro walk behind with a sulkey. The past week when I shut off the blades (blade switch) when the machine is hot I can't get them started again until it cools. All wiring and connections are o.k. and I have jumped all safety switches one at a time and nothing seems to work. I suspect that the electric clutch is starting to fail but would like to know for sure before I replace it. If you've run into this before or know how to troubleshoot an electric clutch I would appreciate it if you would clue me in. I'm not a fan of replacing parts until the problem is solved - troubleshooting is where it's at. I do have a mechanical background with some electrical just not in small engines. Thanks in advance
Eden Scapes |
EdenScapes
Re: Blade Clutch Quits When Hot
hate to answer my own post but I have found the problem and will give it for anybody else who runs into this in future. Talked to Snapper Corp this morning and they recommended I check the air gap on the clutch. Supposed to be .012, it was a lot more than that. A feeler guage and ten minutes and it was fixed. Just might save somebody a couple of hundred dollars some day in lost business and repair charges.
Eden Scapes |
Lawn&Landscape
Thanks for the info...
www.alwaysgreenerlawn.com |
| Blade Wobble New Miter Saw | balanceact | Finish Carpentry | 7 | 06-03-2008 09:12 AM |
| What Blade do you use for Laminate Flooring? | dayspring | Tools & Equipment | 8 | 01-21-2007 02:04 PM |
| So what diamond blade DO you use? | lukachuki | Masonry | 15 | 01-03-2007 01:24 PM |
| What's your opinion? | dayspring | Finish Carpentry | 40 | 03-12-2006 12:03 AM |
| Very small/thin table saw blade | Woodcrafter74 | Tools & Equipment | 25 | 12-28-2005 07:25 AM |
