Another New Grass Question
Old 06-29-2009, 01:08 PM   #1
6stringmason's Avatar
Trade: masonry
I just did my first mow on the new lawn.
I started by spraying round up grass and weed killer on it. That killed everything. Let that stay on for about 5 days, then I tilled it up to a depth of probably 3-4 inches or so.
Then I let that sit while the clumps dried up for about another 5 days. Next step I did was get a power rake and go through the whole yard and break the clumps up. Then I of course picked all the larger clumps up and leveled everything that needed leveling and did clean up of unbroken clumps and dead debris.
Then I fertilized, then reseeded. I laid it on pretty thick. I read somewhere about 15 seeds per sq inch. Now I didnt get down and count, but the lawn was fairly white with seed.
Well it started coming in, I watered it enough. The growth you see there is 3 weeks after I saw the first blades pokin through.
Now Im starting to get deadspots like you see in the pictures. I also have some spots that didnt grow that well. Which leads to my question. What is the best way for me to seed it again to get it thicker, and what should I do about the dead spots?
I didnt get a ph test done. The grass I planted is a mix specially designed for a store up here for our climate and most soil conditions. I have good black dirt all the way around. I have a call in to find exactly what types of fescues it is a mix of.
Anyway, here are the pictures.
And here is what the good spots look like.
Most of the lawn is pretty good, but I'd like it thicker.
Kamps Masonry & Concrete Countertop Design Green Bay, WI
920-680-3195
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
Old 06-29-2009, 01:28 PM   #2
Trade: masonry
Re: Another New Grass Question
%25 Creeping Red
%20 Hard Fescues
%20 Kentucky Blue
%15 Perennial Ryes
%20 seed coating
920-680-3195
Visit our website @
Old 06-29-2009, 01:55 PM   #3
tkle's Avatar
You just wanted to show off... Nice yard, but where's all the fancy brickwork?
It looks like a high traffic spot on the way to the shed. it may have been packed with water collecting where it settled. Maybe water bleeding off of the corner of the planter.Perhaps a bit of sand to break it up a bit and some more seed. Perhaps some stepping stones where it gets narrow.
tkle is offline
Old 06-29-2009, 01:56 PM   #4
Capra aegagrus
Tinstaafl's Avatar
I'm just a hammer-swinger, but I don't think I'd have put poison in the ground as a good way to start a new crop.
I think I'd just try scratching the area up with a rake and re-seeding. If that didn't work, for such a small area I'd look at one of those "as seen on
TV" mixes with seed, fertilizer and mulch all in one.
Tinstaafl is offline
Old 06-29-2009, 03:50 PM   #5
BobsLandscaping's Avatar
Trade: Landscaping
Yeah, Round Up was a bad idea. Try topdressing with steer manure, I suspect a nitrogen deficiency. A soil test will be definitive.
BobsLandscaping is offline
Old 06-29-2009, 05:16 PM   #6
Trade: masonry
Thanks guys. The roundup was suggest by a grass guy, cant think of the professional name, who went to school for it. It not real potent the bottle says you can reseed after only 3 days. I waited almost 2.5 weeks between everything.
And tkle, no brickwork lol. The yard is relatively small. Maybe three tenths of an acre.
920-680-3195
Visit our website @
Old 06-29-2009, 08:22 PM   #7
jomama's Avatar
Trade: Concrete & masonry
6string, I think I would just keep mowing it as needed. Everytime I plant new grass at home, It seems like it takes months, if not seasons to fill in nicely. You may also want to set the mower a little lower as it fills in also. Good Luck!
jomama is offline
Old 06-29-2009, 08:25 PM   #8
Trade: Landscaping
Don't set your mower below 3 inches. You'll scalp the lawn.
Old 06-29-2009, 08:30 PM   #9
Lack Of All Trades
Darwin's Avatar
Trade: Professional handyman services
looks like you need to aerate the lawn. looks like that soil is clay.
Darwin is offline
Old 06-29-2009, 08:49 PM   #10
Trade: masonry
I've got it on the highest setting, and I sharpened the blades.
The soil is good black dirt in case you didnt read the original post.
As far as aerating, is that to be done even on a new lawn? I mean I tilled it all under and started fresh, wouldnt that aerate it good enough?
And like I said before, thats only 3 weeks of growth. I've been watering religiously. I was just worried about the brown spots.
920-680-3195
Visit our website @
Old 06-29-2009, 09:32 PM   #11
mason
DQM's Avatar
Trade: Mason contractor
It looks good fine job just needs a little touch up. Went through the same thing with my lawn .I spread a little black dirt some seed in bad spots and now its almost perfect give it time. ( its not sod)
DQM is offline
Old 06-29-2009, 10:20 PM   #12
Stevelsc8721's Avatar
Trade: We perform landscape design and construction
Next time till it five or more inches to break up the hard pans of the property. Install some fine screened new topsoil because it will have some nutrients in it and try a starter fertilizer super phosphate.
Then water three or more times a week to keep it moist, don't let it dry out.
Cutting if you want the energy to go to the root system try cutting it three or more times a week that will help with the thinness problem.
Stevelsc8721 is offline
The Following User Says Thank You to Stevelsc8721 For This Useful Post:
6stringmason (06-29-2009)
Old 06-29-2009, 10:33 PM   #13
Trade: masonry
Great info! Thank you!
920-680-3195
Visit our website @
Old 06-29-2009, 11:32 PM   #14
Crash Test Dummy
ChainsawCharlie's Avatar
Trade: Landscaping
I doubt the roundup is the issue. It goes inert after 48 hours.
Unless it's Roundup Extended. If that's the case, the rest of your lawn will likely be going away as well.
What did you use to put the fert down? Maybe you got some hot spots.
ChainsawCharlie is offline
Old 06-29-2009, 11:35 PM   #15
Crash Test Dummy
Trade: Landscaping
That's how the golf courses do it.
One note on watering-more frequent watering with short times will encourage the grass to spread.
Less frequent watering with longer times will encourage deep root growth.
Question from lawyer trying to help contractor scp Business 52 02-25-2011 01:23 AM
Condensation question Jim R General Discussion 7 02-05-2009 07:33 AM
Contract question MACEXCAVATING Excavation & Site Work 4 12-20-2008 09:24 PM
