Wanted - Commercial Construction Sub Trade Scopes Of Work For Estimating
Old 05-24-2011, 12:13 PM   #1
rblank's Avatar
Trade: Construction Management
Rewards Points: 75
Sorry for the long title, but I'm trying to be as specific as possible so I don't waste people's time. I'm a PM for a smallish ($4M - $7M annual volume) commercial construction manager. We have a very bad habit when estimating projects of not sending out a scope of work to each trade telling them specifically what we want them to price. Some of the other PM's here don't even send out specs , but I digress.
What I'm looking for, and hope my CT brotherhood can help me with, is a general template starting point for developing a scope of work for each specific sub trade. I know that each project will require me to go through and add very specific information relating to plans and specs, which I'm usually pretty good at. A home builders "I'm going to give you WRC R & R shingles and three 24" x 48" double hung Andersen windows" doesn't really apply here. Am I going into uncharted territory here? I'd be surprised if I was.
rblank is offline
Old 07-06-2011, 08:01 AM   #2
rblank's Avatar
Rewards Points: 75
Re: Wanted - Commercial Construction Sub Trade Scopes Of Work For Estimating
232 views and not a single response?
Ok, how about we try it this way. Anyone have a scope they've received as part of a subcontract they did, and were impressed with?
rblank is offline
Old 07-06-2011, 09:25 AM   #3
PRO
BrandConst's Avatar
Rewards Points: 1,000
Do your plans not come with specs already? I've never done this, it's the subcontractors responsibility IMO to address all items that fall within their realm of the scope. If I had a sub that couldn't do this, I wouldnt accept his bid. It all comes down to bid day, it's your job to better qualify the scopes.
BrandConst is offline
Old 07-06-2011, 02:51 PM   #4
rblank's Avatar
Rewards Points: 75
My plans and projects usually come with specs, but not always. Here's a specific example of a problem I ran into that is why I started this thread.
http://www.contractortalk.com/f84/fl...imating-98958/
I like to be PROactive, as opposed to REactive, so I'm looking for a way to make sure I don't have any holes in my bid before bid day. That way I don't have a problem with "bid qualifications, inclusions, or exclusions", and I know everything is covered before hand.
rblank is offline
Old 07-06-2011, 02:57 PM   #5
PRO
BrandConst's Avatar
Then use this, put it in an excel spreadsheet and require that your subs note every code on there proposal and check them off as they go. Most commercial subs will note this on there bids anyway.
Old 07-07-2011, 07:26 AM   #6
rblank's Avatar
Rewards Points: 75
I appreciate your input and help with this, I really do. But putting in the CSI headings isn't going to help me in the case from my link. Two trades could have included the section for flashing, but didn't.
Where I fall on my face is making sure one of those two guys doesn't miss it, when I send out my bid packages.
Maybe I'm looking for a quick solution where it doesn't exist? I can't believe that no one has a scope of work template that they use, everyone refers to it, but no one will post one.
rblank is offline
Old 07-07-2011, 07:33 AM   #7
PRO
BrandConst's Avatar
Yea....I think your trying to re-invent the wheel here. Your making it harder than it really is.
Other trade doing shoddy work - how to break it homeowner? barefootbuilder General Discussion 35 09-14-2010 08:11 AM
HOW do I find Commercial tenant finish out work adg General Discussion 1 06-08-2010 08:23 PM
Commercial Construction NJ AmeliaP Contractor Licensing 4 03-23-2010 01:11 PM
Heavy Construction Foreman/HEO Looking For Work jleebow Help Wanted or Looking For Work 0 12-04-2008 05:15 PM
Proposal for commercial work sttryffe Painting & Finish Work 1 09-30-2008 03:29 PM
