Help On Test ?, Please!
Hey all
I'm another newbie here. I'm studying to take the contractors test and am stuck on a few questions. I would sure appreciate some help. Here's one. A 16' X 80' X 6" patio. 50.00 per cubic yard for material and 5.00 per square yard labor cost. I get 1185.00 for material and 711.11 for labor for a total of 1896.00. The correct answer is 1986.00. What am I doing wrong? Thank you for your time. W.B. |
#2 | |
Insert title
Trade: Doors-Windows-Decks
Re: Help On Test ?, Please!Quote:
Edit: 1915 if I round up.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company. Last edited by dougchips; 04-25-2007 at 10:20 PM. Reason: edit |
Recovering IT Guy
Trade: Handyman, Home Improvement, Kitchen & Bath Remodeling
Maybe their answer is a typo (transposed numbers). I worked it first then looked at the answers you got, and came up with the same numbers.
Second Look home improvement www.SecondLookHome.com Handyman and Home Repair Specialist in Rhode Island RI Licensed Lead Safe Remodeler/Renovator, RI Registered & Insured Contractor |
Thanks fellas, It dosen't give any information about rounding up or anything else. I passed it off as transposed numbers myself untill I went on throughthe tutorial and got to another question and couldn't get the "correct" answer on it either. I have to leave for work and will post the other question this evening. Thank you for the help. This is a great site!!!
W.B. |
Trade: Renovations
I got your answer too, I think it's a typo.
Super B
The labor is correct but the material is under. Figure a 4" slab and divide by 81, this is a 6" slab so add 30% to your concrete. I get $2,031.10 without crunching the numbers.
Trade: Renovations
Skyhook, I think you need to crunch the numbers...
eg. if you increase from 4" to 6", that is a 50% increase not a 30% increase. 16' x 80' x 1/2' = 640 cubic feet/27 =23.704 cubic yds x $50 = $1185.185
Professional
Trade: Finish Carpentry
I get 1896 also. Looks like a typo, the 8 and the 9 got switched.
What study materials are you using the prepare for the test? |
#9 | |
Super B
I sure do appreciate the responses fellas. Mexifornia, the study material is from National Contractors Pre-License Services, Knoxville TN.
I have another one for you. A block and brick building 19' x30' 6" with 10' walls. The wall diagram has 4" of brick, 2" air space and 8" block, brick on the outside of course. How many brick @ 7 per sq. ft and how many block @ 1.125 per sq. ft. I came up with 6930 brick and 1069 block. The answer in the tutorial is 6900 brick and 1039 block. I think it's odd that I'm 30 over on both. I've been studying hard and the more I study the more shook up I get. One question was about icedam protection flashing. The IBC book says 3 ft and two of my other books says 2 ft up the roof from insulated walls, so 2 ft from the wall may be 3 ft or more depending on the overhang but they want a a,b,c or d answer. So the more I study the more I wonder!! Sorry so long winded guys. And thank you for your support! W.B. |
Trade: Renovations
Skyhook, I like your price better, too, but the price I really like is $50/yd for concrete! When was this test written? Or is that the price these days in Tn? Here, it's around CAD $155/yd
Cake Decorator
Trade: Masonry
On those masonry ?'s thery're supposed to give a detail. 4w2h8L brick /w 1/2 joint. Block, mortar joints are included .8/8/16. Remember the state wants you to pick the BEST answer outta four mutiple choose answers.Most of those math ?'s are given to you w/a little preperation.Those other ?'s I hate it when they try to stump you w/ two correct answers. It' s what the state requires you to know.Some are BS ?'s that are unrelated to your trade. I d go through your study materials , weed out the ones you disagree with.{ those are gonna really shake you up]and have them corrected by the school. Remember BEST answer. Good luck.
#13 | |
I'm a Mac
Trade: ICF Construction
Chris |
Thanks again for all the responces and advice. You all helped me calm down. Chris, I'm into the business law pretty deep now. It and OSHA are going to be the toughest I think. I'm scheduled to test 5/16, I'll let you all know howit goes.
Thanks W.B. |
If you add your thickened edge of about 12" wide by approximately 6" on 3 sides (80/16/16)you will get much closer...
Working slopes and waste in the corners.. well you get the idea.... Still need to order more than you will use.... Hmmmmm Good luck!! Last edited by scottward; 05-17-2007 at 03:08 PM. |
Hey Fellas
I passed both test! Thank all of you for your help. WB |
General Contractor
Trade: General Contracting and Painting
Re: Help On Test ?, Please! |
| illinois residential roofing test | the roofman | Roofing | 17 | 05-27-2009 08:34 AM |
| Master's test Ky. | Moonray | Plumbing | 6 | 04-13-2008 08:42 PM |
| Operating Engineer Apprenticeship Test | biggixxerjim | Excavation & Site Work | 3 | 01-07-2007 07:27 PM |
| NYFD Refrigeration test | 6419joseph | HVAC | 0 | 08-27-2006 03:54 PM |
| apprentice test | drywaller56 | Plumbing | 3 | 02-22-2006 08:02 PM |
