Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Excavation & Site Work
Old 08-15-2008, 07:52 PM   #1
General Contracting
LNG24's Avatar
Trade: Real Estate Broker, Property Manager
Weight of Item 4 (Crushed Stone)
Anyone have the weight of Item 4 or Crushed Stone? Can't seem to find it on line right now.
LNG24 is offline   Reply With Quote
Old 08-15-2008, 08:08 PM   #2
JPC2's Avatar
Trade: Fine Homebuilding, Remodeling
My Architectural Graphics Standards book says:
Granite, limestone, crystalline 165 pcf
Limestone, oolitic 135 pcf
Marble 173 pcf
Sandstone, bluestone 144 pcf
Slate 172 pcf
JPC2 is offline   Reply With Quote
Old 08-15-2008, 08:10 PM   #3
JPC2's Avatar
Also found:
Sand or gravel, dry and loose 90-105 pcf
Sand or gravel, dry and packed 100-120 pcf
Sand or gravel, dry and wet 118-120 pcf
Old 08-15-2008, 08:14 PM   #4
General Contracting
LNG24's Avatar
Humm,
That might get me close. Thanks
Old 08-15-2008, 09:00 PM   #5
tgeb's Avatar
L the weight of stone varies greatly depending on the "make up" of the actual product you have locally.
Here I estimate around 3,000 lbs per cubic yard, and that usually gets my jobs done with a little extra.
The most accurate way to figure this is to contact the quarry where you will be getting your product. They will know what the weight to volume ratio is.
www.gebcon.com
tgeb is offline   Reply With Quote
Old 08-15-2008, 09:34 PM   #6
LNG,
You will buy Item 4 by the TON. It should weigh 2,000.00 pounds!
Crushed stone 2,400 to 2,600 a yard. Item 4 3,000 plus if wet.
Nick
"Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein
denick is online now   Reply With Quote
Bleeding Stone Wall sxdirt Masonry 9 08-11-2008 07:31 PM
crushed stone volume to tonnage?? Aframe Excavation & Site Work 8 04-18-2008 10:10 PM
Stone Wall Pricing CJKarl Masonry 45 01-09-2008 08:23 PM
Mortar Bedding for Stone on Concrete Question. lukachuki Masonry 10 05-26-2007 09:09 PM
