Water Main Leak Detection
what methods have any of you used to detect a small water main leak that will not expose itself?
someday, i'll be as patient as Nick. |
Moderator
Re: Water Main Leak Detection
If you are chasing this with listening equipment, you might try nitrogen gas introduced into the line to get the leak to bubble, gurgle and hiss a bit. This can sometimes help hearing what otherwise can't be heard.
I assume this is on a purveyor's main or is it a service line?
#3 | |
Re: Water Main Leak DetectionQuote:
3300 l.f. of 6" class 200 IPS sized pvc and in a granular soil. we're losing about 4 gpm, won't expose itself
Hate to be a PITA but how deep are we talking ? Don't even know if this is feasible but what if you pumped steam from a steam cleaner into it and then shot the area with some sort of inforead camera.
Moderator
By me on that one. I have no experience chasing leaks on that large a line.
7' of cover on the pipe, was just googling and found out there are methods of injecting either helium, or hydrogen into the main, and using a "sniffer" to find it. we've tried the audio "earphone" type, but way too much side traffic to hear anything.
sam74
Trade: Civil and Site engineer
Can't you narrow it down in between valves on the 3300 lf
there are 2 valves...where we start, where we end.
sam74
Back in my inspection days I've seen a contractor install a valve in the middle and go at it from there until they can isolate it more closely. But that was a 50 plus mile long job with five crews and probably a drop in the bucket to them. Probably a job specefic decision. I guess it depends on how much money it is costing you a day. Are you still mobilized?
I wouldn't go with Hydrogen, one stray spark and you might be reinstalling the whole thing.
Shut down traffic for about a half hour!!!! Joking....maybe? We actually did that on a 100ft section of 24" so the guy with the earphones could find the leak. That, or have them check it at night when traffic is at it's minimum.....Sorry, I tried. Anything works cept for digging it back up one joint at a time!
Trade: Plumbing & Gas Contractor
I know it's 7' deep but unsure on the compactness.How about walking the line and probing for the wet spot every so often.You may hit a water pocket?!They still walk gas lines.
this is in a new roadway. we had to have 95% of standard proctor density wise, with soil tech's taking tests all the time. it's HARD!!
Trade: Ultility Contractor
Just keep pumping it up hopefully it will surface, try a leak detection service they are pretty good with our experience, we have pushed rods down in the ditchline the water will its way out.
If you have any fittings dig them up for the listening service to get on to listen. pvc is hard to listen on what is the pressure you are running with. On shorter runs we have dug up every joint |
Trade: Repair & Restoration Contractor and Specialty Graphics/Sign Installer
walk parallel to the main line you suspect is leaking, about 5' away on both sides with "divining rods". just us coat hangers, about 12" long with 90 degree bend for a 4" handle, hold them loosely. you are looking for the water running away. Don't believe me. walk over where you know the main line is and see if they respond. Done it many times, just as deep.
Tin Cup |
Professional Remodeler
We hired a company that specialized in leak detection. I took over a housing community construction project a few years ago that was losing water. It took the tech three nights between 1:00 am and 5:00am (quietest time, the project was between a major highway and major street), but he found two main leaks, three leaking toilets, and several leaking sprinkler valves.
-Mike- Falcon Contracting Residential - Commercial
| 1:12 pitch roof and water pooling | KesslerDweller | Roofing | 3 | 11-28-2007 09:48 PM |
| Main v.s. Load 2 Gang Meter | Bubbles | Electrical | 5 | 10-05-2007 08:05 PM |
| #&*@! Water Hammer! | Mike Finley | Plumbing | 19 | 02-22-2007 11:47 PM |
| Hot Water | Joewho | Plumbing | 13 | 11-17-2006 02:39 PM |
| Brick Footer and Water Proofing | emtaboy | Excavation & Site Work | 24 | 07-24-2006 09:48 PM |
