Using A Bobcat To Fill A Dump Truck
will a bobcat clear the sides of a typical 20yd dump truck? If not, does a T250 or T300 have a higher reach for dumping purposes?
Handle It!
Re: Using A Bobcat To Fill A Dump Truck
Bobcat, New Holland, Etc. ............Nope! not your typical ones. MAYBE a Versa-Handler!
I guess I should ask "What Unit" Before my answer............
Something to One may be Nothing to another! Ultimate Wisdom--------- http://www.youtube.com/watch?v=OW-cnizLDEE Last edited by MALCO.New.York; 01-05-2009 at 07:18 PM. |
I have a Case 410. Not a problem if you build about a 2' ramp to back the truck up along.
Trade: Builder/Developer
If you are talking a typical 10 wheeler...no problem with my S250. I can load em all day long. I don't think you'll have much luck with a smaller machine...the 250 and 300's have a slightly higher reach.
Sam |
Depends on what you consider typical.
If you mean the high sided quarry trucks, no a skid loader can't load those with out a ramp. I have loaded plenty of tri-axle and tandem dumps that have lower sides with no problem, I can fill em till it rolls off the other side. I have used a new holland 665lx for years, it has better reach than the comparable case, cat or bobcat. The bobcat t250/t300 will load a pretty big truck. What are you trying to do 72? |
Midnight
Trade: Excavating, Grading, Demolition, Underground Utilities
T-300 has a higher reach than the 250. We have 250's and have to build ramps to load quads with boards. t 250 will load most tri-axle's though. That's my 2 cents.
"It is what it is" |
Trade: Natural landscape enhancer
gotta make sure its a "high lift" bobcat they have an extra portion between the boom and the machine frame it sticks up behind the cab more
Trade: Trenching, Grading, Drainage, Fencing, and more!
I have a John Deere CT 322 (reach is 8.5 ft) and in order for me to fill a tri-axle I have to use my gooseneck trailer to server as a ramp. It works great! My machine is lifted an additional 3.5 ft and even though to set it up by lowering the landing gears, to serve as outriggers, can become a pain, it is well worth it by getting the job done. I have done this many times.
Of course not all sites will accommodate the room to set this up. Hope this helps?
You don't know half, until you know all" - My quote Fulcrum Services, LLC www.fulcrumservicesllc.com |
| dump truck advice | Big Chris | Excavation & Site Work | 23 | 04-08-2010 09:46 AM |
| 10 Yard dump truck on call, NJ | brm1109 | Help Wanted or Looking For Work | 13 | 12-03-2008 07:10 PM |
| Dump truck Rates | Lakeman2008 | Construction | 2 | 06-27-2007 03:11 AM |
| Finally used my POS dump truck today | IHI | Vehicles | 7 | 03-30-2006 12:37 AM |
| Bought me a dump truck tonight:) | IHI | Vehicles | 1 | 01-07-2006 12:47 AM |
