Trade: Excavation Contractor
Using A 90 For Cleanout At End Of Main?
I have a logic question. I missed an important plan detail on a project, and as a result I ended up using the information given to me by a large pipe supplier in the area. We extended an existing sewer main by dropping a new manhole at the existing clean-out and proceeded to run 110' to the end of the project. The pipe supplier sent me an 8" 90 deg elbow of which we installed. The engineer never said anything, and it is now buried. Problem is, standard detail drawings specify two 45's
Ultimately it is my mistake and if they make us dig it back up then I have zero problems doing so. However, my question is wouldn't the 90 serve as a one-way clean out especially considering that the manhole is going to be utilized 99% of the time for any maintenance. The original problem with the project is that the engineer assumed that the existing clean-out was a 90 but was instead a standard double bend 45. This in turn left us without enough room to tie in the manhole and thus we had to move it forward in order to grab a good clean run of existing sewer. Moving forward, the plans call for the sewer to stay on grade until the very end of the project..A 90 is in fact the same profile as a 1-way clean-out so why would this be a problem? I am a little frustrated that I missed this in the beginning and everyone's "logic" led us down the path of placing a 90 at the end. I'm sure you have all been in similar situations where you thought you were following the plans to a tee and then later find something in the small print that changes everything |
Vagitarian
Re: Using A 90 For Cleanout At End Of Main?
Hmmm....every sewer authority that I have dealt with doesn't want to end a main with a cleanout, but they want a manhole. Personally, I would rather have a 90 instead of (2) 45's. With (2) 45's there is greater stress on the joint's from the backfill and could cause a leak or breakage. In my experience with inspectors, I doubt that anyone would discover your mistake.
unless they want to get a jetter/cleaning equipment thru it
someday, i'll be as patient as Nick. |
#4 | |
Re: Using A 90 For Cleanout At End Of Main?Quote:
Man I love this stuff despite the hassles we encounter at times......always a challenge and always something new to learn.Thanks for the input guys, Jason Last edited by cexcavation; 03-17-2009 at 09:47 PM. |
personally, i'd take the 2-45's hands down, 90's on sewers are trouble.
I agree in most cases, and definately hands down in a flow situation. However, there is always that situation that differs and I think this may be one of those cases. Also if you take a standard one way clean-out and hold a standard 90 next to it, the profiles are identical with regards to physical access to the line. Taking that into consideration, a lot of the phobia associated with using 90's for clean-outs is somewhat un-founded if a one way or two way clean-out is deemed adequate-they are the same thing only one is midstream whereas the other (the 90) is at the head of the stream. Just one of those things that comes up and is good food for thought. I typically use 90's for clean-outs on all French drains since typically I want to extend the drain directly against whatever I am trying to protect. This sewer system is designed around the idea that the sewer stays on grade right to the clean-out station.
the theory behind using 2-45's...is that it will give you a more gradual sweep on your radius allowing cleaning equipment a better chance of making the curve.
Trade: site work
What i probably would have done is a twye with a 45 and a plug in the end. you would have left it set up for the next guy to take off or your self if you could get the next part of the job.
| Compression T Fitting vs. Re-Threadding Galvanized Water Main | mtbmac | Plumbing | 47 | 09-14-2008 12:33 AM |
| Tapping into Galvanized Water Main | mtbmac | Landscaping | 2 | 09-06-2008 05:44 PM |
| main trips | pat c | Electrical | 13 | 08-20-2008 07:05 AM |
| Main v.s. Load 2 Gang Meter | Bubbles | Electrical | 5 | 10-05-2007 08:05 PM |
| Main beam sagging 1/2 inch? | AllGoNoShow | Construction | 10 | 10-12-2006 08:20 PM |
