#21 |
Trade: Concrete, masonry & excavation
Re: Underpinning
I have done some underpinning we usally dig 4' and skip 4' we use pnematic clay diggers a easier that pick and shovel to brake up the material. then pour footing and them 1 sided forms poured to the top and if neccsarry we use ns grout on top to pack in the voids.
#22 |
General Contracting
Trade: Real Estate Broker, Property Manager
Re: Underpinning
Guess whats underway? Yep, I finally started the underpinning. After a year of on and off discussions with an engineer, surviving a winter with hay bales protecting the exposed footing and constantly pumping water out, I jumped in and did it based mostly on what you guys told me anyway.
What we ended up doing was to dig back (by hand Here are the pics. Will keep you posted. |
#23 |
Professional Instigator
Re: Underpinning
Did you grout between the foundation wall and the new footing?
#24 |
General Contracting
Re: Underpinning |
#25 |
Re: Underpinning
understood
#26 |
Trade: Excavation
Re: Underpinning
What is going to stop the frost from penetrating THROUGH the base of the foundation wall and old footing, and freezing the clay that is still under the back side of the footing? The frost can still grab the soil and heave the footing.
That's why I always excavate the entire width of the footing, and usually form against the dirt at the back with a couple inches of SM. Pete |
#27 |
Re: Underpinning
Here is a job that still on going 1 building has been underpinned the other is in the works.
#28 |
Re: Underpinning
Here are a few more.
#29 | |
Re: UnderpinningQuote:
![]() ![]() Where are you getting this? If the bottom of the footing is below frost, that's the end of the story.
#30 | |
General Contracting
Typically, underpinning is done to carry extra weight of lets say additional stories added to the top of the building. Or you might have to do it if you are excavating a building next door deeper than the existing building. In my case, none of this was present, we simply needed a Frost Wall, in fact the engineer said just building a concrete wall out of cinder block directly in front of the footing would be sufficient. I liked this version better. I created this problem by calling it underpinning to begin with. It would be no different than building a frost wall around a poured slab. Last edited by LNG24; 10-13-2008 at 07:44 PM. |
#31 |
Trade: Outdoor D/B
Re: Underpinning
So lets say I buy alot in a city and want to build a building with a big basement. The building next door 5 feet away just has a crawl space. If the other owner doesn't want me to underpin his building and I out of luck?
I am just curious how the works. I am not really buying anything. |
#32 |
Re: Underpinning
If the building is 5' away and you will still undermine it in building your new basement and they do not want you to underpin. Then you would install soilder piles and lagging on the property line. If you can not install tiebacks into there property then usally you install steel H piles with a 1-1.5 toe as long as the soil can hold it.
#33 |
General Contracting
Re: Underpinning
My walk out is finally done. Well, except for putting the bluestone on the steps and top of wall.
Here ya go: |
#34 |
General Contracting
Re: Underpinning
and done...
| The Following User Says Thank You to LNG24 For This Useful Post: | algernon (11-07-2009) |
#35 |
It's all about the Avatar
Trade: I have no face!
Re: Underpinning
I too am confused, this is a walk out. The footing is only 18 inches deep. If you do not get frost there then I see no problem, but in a lot of places across the country frost goes to 4 feet… and that footing is not protected. If it was put in a heaving condition there are no piers or piles to keep it from moving.
#36 | |
Really helps out the basement area. |
#37 | |
General Contracting
Where did I confuse you? Footing/Frost Wall is now down 42" not 18" |
#38 | |
Trade: worker
Bill |
#39 |
Re: Underpinning
Ok here is a simple, layman answer the new underpinning makes up for the dirt removed
So if you remove 2' of dirt the underpinning is 2' further down under the dirt. So the footing is not exposed it is now back to the same depth as it was be cause of the underpinning. Not really 100% accurate just making it laymen like |
#40 | |
You can get waivers in most areas if the neighbors don't comply. Having them sign off just makes the process easier and faster to get the city approvals |
| Deepest underpinning | ch0mpie | Excavation & Site Work | 27 | 12-01-2008 05:48 AM |
