sam74
Trade: Civil and Site engineer
Sources Of Sand
Hey, I'm specing a grasspave product (reinforced grass surface) which requires the plastic reinforcing grid to be backfilled with builders sand. Is builders sand just quarried sand?
Where the job is located (North Carolina Mountains) concrete is an expensive product. Which makes me think there are not many rock quarries in the area. I have found a sand company that sells "river sand" which they say is used in concrete around there. Does anybody have any thoughts. |
Captain of the Titanic
Trade: Asphalt Paving,Excavating, Masonry
Re: Sources Of Sand
I would say builders sand is probably a course grain sand much like concrete sand. Stone dust or manufactured sand would probably also do it, but natural sand is probably cheaper.
Most of the flat work products out there for driving surfaces spec a course grade sand. I'll bet the river sand you speak of is good for that, if they told you they use it in concrete. I have priced a couple of those jobs recently and concrete sand or stone dust is what I'll use if they come in.
Roccies Asphalt Paving The Right Way Driveway Company If you say you cant, your a loser. If you say you wont, your a quiter. Which one do you want to be? Last edited by Vinny; 09-22-2007 at 06:37 PM. |
Re: Sources Of Sand
I've noticed that when any product being referred to as "builder's"-anything, they just mean something regular, ordinary, and nothing special.
Re: Sources Of Sand
I think what you are looking for is sand that is angular. For instance, it has sharp edges as opposed to smooth rounded edges.
Sharp angular sand is more structural in that it will "lock" together. Smooth sand (think play ground/ sand box) has smooth rounded edges and is less structural in that it will not "lock" together. A quick look at a handful would give you an indication of what you have there with the "River sand". E-Mail me a sample and I'll take a look at it, if you like. |
Re: Sources Of Sand
Well one thing for sure, river sand is probably more round than sharp. This may be best done with manufactured sand like "stone dust" or "stone fines". The aspahlt plants normaly use this for mixes and most mason yards carry it also.
But I also know from experience and going to a couple of training events for these typs of products a generaly available course sand is fine. Like shunk said, builder grade, run of the mill. Keep in mind only 1" is used in this application for a clean setting bed. Below that is where processed stone base creates the stuctural stability needed.
Roccies Asphalt Paving The Right Way Driveway Company If you say you cant, your a loser. If you say you wont, your a quiter. Which one do you want to be? |
#6 | ||
Re: Sources Of SandQuote:
Can you get a little more specific on what you are doing Steve? |
Re: Sources Of Sand
Yea Tom, I assume somthing like that. Either plastic or concrete is what the thread starter was thinking. I thought the geogrid material he mentioned would be used subsurface to add stability to the base and after a 1 inch setting bed is installed the grass pavers, plastic or concrete, would be placed and then top soil and seed. Ether system can handle traffic.
Is that your crew doing that install in the picture? Looks good. Those are plastic, right?
Re: Sources Of Sand
Looks like Ecogrid in those pics.
If this is something like he is using then he does need like stated before a sharp edged sand or a very fine crushed rock with fines or crushed with binder as we call it around here |
Re: Sources Of Sand
No, I just swiped those pics off the Net.
We have never done this type work, but do get involved in the concrete pavers occasionally, and have looked at these open grid systems before. |
sam74
Re: Sources Of Sand
Hey guys, thanks for all the responses. The pictures above are very similar to what we will be spec'ed. Final product choice has not been made yet. They are considering grasspave 2 or Modi garden grid. This product will take the place of a currently mostly graveled fair grounds site which receives large truck traffic on some events. I did some more research and found that builders/concrete sand is being used for its angular nature which would help it lock together. I ended up getting a hold of a local contractor who was able to offer a good local unit price.
Thanks again |
| What kind of sand for pavers | EDENSCAPES@DNET | Landscaping | 37 | 10-08-2010 02:00 PM |
| Matching sand finish? | Thewallfixer | Painting & Finish Work | 11 | 07-14-2007 12:08 AM |
| White Sand - does it contain free silica ? | plazaman | Masonry | 3 | 06-24-2007 10:44 AM |
| Parking lot- sand or no sand? | gdavis | Excavation & Site Work | 6 | 01-08-2007 09:08 PM |
| sand or soda blasters... | painterofeveryt | Painting & Finish Work | 4 | 11-02-2006 08:51 PM |
