Youngster
Trade: Builder / Consultant / Designer
Soil Conditions?
I've attached a scan of the geotechnical study on my lot. I have two questions for you guys who are more familiar with excavation.
Re: Soil Conditions?
no found drainage, needed
Midnight
Trade: Excavating, Grading, Demolition, Underground Utilities
Is it going to be a full basement or crawlspace? You will probably need to remove the silt portion from under footings but if you are going to be through the silt with your foundation then it will not be a problem. If it is a basement you will definitely need foundation drainage especially with that layer of silt water doesn't move through the silt like it does sand. Also during construction the silt will likely become unstable if you decide to leave it on site flip flop it for sand in a landscaped area. That is just my two cents.
"It is what it is" |
Youngster
Full basement. My footings are going to be around 6.5' deep which should put them in the gravel layer. Also I will be backfilling with the gravel/silt/sand mixture. Do you really think I'll have a drainage problem?
you realize just how cheap drain tile is? sump pumps are cheap, pump pits are cheap...i'd put it in myself. i live on a lake, very sandy material, my basement floor sits 6' over normal high lake elevation. in the flood of 97, the water table came up through the cracks in the floor, being it was so high off the lake, sandy soil....the builder didn't put any drain tile around it...i bought all new sheetrock/carpet. ended up with 4" of water in my basement. the city had us plug our floor drains because all the sewer mains were being inundated due to the flooding, so we couldn't let it go down the floor drain
someday, i'll be as patient as Nick. |
Youngster
Don't know how far above the water table I am, but I'm on a hillside about 500' off the valley floor. Went down 11' with no sign of moisture.
But you're right. Drain tile isn't expensive. Probably worth the cost. It's just the little things like that are gonna nickel and dime me to death. |
o brother
Vagitarian
Pay now or pay later.
It won't be too cheap to dig up the foundation and add drainage in 2 years.
Put it in now, here it's code for basements. Where are you located? |
Youngster
Northern Utah
Ca,
There is no code requirement in Utah for drainage or damp / waterproofing?
Nick "Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein |
Trade: excavating
Around here we almost never encounter a water table. Soil is usually a heavy clay or shale. Ground water is not a problem, but EVERYBODY waterproofs (tile, rock, pump) even walkout basements (w/o pump) its a nothing cost that saves big problems.
"The beatings will continue until morale improves." |
PRO
Trade: CGC Concrete
Here in florida it hard to dig 3 feet without hitting water. No basements here.
Trade: custom home building
If you put in tile and all is well after 20 years or so, you can dig it up and sell it on e-bay. Especially the t's and crosses are going to be worth a lot in the future.
| Crawl Space Ventilation | Ed the Roofer | Roofing | 2 | 11-27-2008 11:15 AM |
| New AIA Supplemental General Conditions | thom | General Discussion | 2 | 04-07-2008 08:31 PM |
| Ground rods for soil with bedrock | MKamis | Electrical | 5 | 03-08-2007 09:47 PM |
| Work Order Terms and conditions | jmejio | Business | 5 | 03-18-2006 05:34 AM |
| Wording for Terms and Conditions | jmejio | Flooring | 0 | 03-11-2006 08:03 PM |
