Skid Steer Tires
Old 09-12-2009, 10:08 PM   #1
Golden Gate's Avatar
Trade: Field work with REO's
Skid Steer Tires
Does anyone have an opinion on skid steer tires, what I mean is there a certain brand of tires that you recommend as being flat resistant. My main problem is this, I use my bobcats for to many different things in to many different conditions. I do demo with them on concrete or asphalt but on the same job I may be out in the middle of the sugar sand, the problem is the latter(sugar) I am told the never flat and foam filled tires ad so much weight that they become a problem, I am thinking of going to the bobcat severe duty tires but they run $400 ea here, I am terrible hard on tires in fact my newest machine a 185 with less then 275hrs well I have now put 2 new tires on it, I visit my local tire guy on a weekly basis just to patch the multiple holes. I run 60 oz's of slime in each tire just to stay ahead of the smaller stuff, I am running the Bcat brand heavy duties which are 12plys and I am seriously considering putting the Bcats severe's on next. I can do everything with a skidder except keep air in the tires. DOES ANYONE HAVE ANY SUGGESTIONS
Golden Gate is offline
Old 09-13-2009, 11:17 AM   #2
tgeb's Avatar
Re: Skid Steer Tires
I have gotten good service out of Firestone Duraforce DT
http://www.firestoneag.com/tirelist.asp?ref=59
I prefer air filled as opposed to filling w/foam for pretty much the same reasons as you. The draw back is you will get flats from time to time.
I keep a plug kit on the truck, and try not to run over stuff.
I have run sets of these tires as long as 800 hours.
www.gebcon.com
tgeb is online now
Old 09-13-2009, 01:10 PM   #3
jmacd's Avatar
Trade: excavating
Have you tried tubes, I have tubes in mine and since that have not had a problem. I used to have over the tire tracks and it would suck to get a flat. I think I have the bobcat super duty tires and still got flats until I put in tubes.
jmacd is offline
Old 09-13-2009, 01:19 PM   #4
mics_54's Avatar
Trade: contractor
2 new tires in 275 hours???? dude..you should kick your operators A55
mics_54 is offline
Old 09-13-2009, 07:26 PM   #5
jmacd's Avatar
Trade: excavating
Good point Mics, I have close to 1000 hours on mine and the machine is on concrete almost daily.
jmacd is offline
Old 09-13-2009, 08:26 PM   #6
I guess I should clarify not just on concrete but actually demoing the concrete complete w wire mesh and rebar so yeah we do have flat issues mostly because I am so aggressive and yes I do own the machines. my question were personel tire preferences based on many different conditions and daily requirements
Old 09-13-2009, 08:49 PM   #7
Williams Ex Co's Avatar
Trade: Excavation, land clearing, sewer/water
My choice? Tracks.... No flats. Yep, the machine is more expensive to own but I never have flats....
Williams Ex Co is offline
Old 09-13-2009, 08:59 PM   #8
mics_54's Avatar
Trade: contractor
Sorry I don't know enough about the solid tires to make a judgement. I have been thinking about them though. I know it's hard to avoid flats in the crap and trash loading.
mics_54 is offline
Old 09-13-2009, 09:25 PM   #9
tgeb's Avatar
Doing that sort of demo work you might look into the semi solids tires.
Cuts down on the weight, looks like you could run them till they fall apart.
http://www.mclarenusa.com/nu-air/nu-...-backhoes.html
If I did alot of demo these are what I would run.
www.gebcon.com
tgeb is online now
Old 09-13-2009, 09:39 PM   #10
Yeah Tom I have never actually owned a set of solids...dealing with what we call sugar sand weight (footprint) is a big issue, I have shyed away from tracks because they are so fricking exspensive. Don't get me wrong I love the way they work in the sand infact I have to rent them occasionally just because of what the job calls for. I have considered going to the 10" wide solids and then getting the steel tracks. I really worry about tearing the rubber tracks up doing what we do. We already tear heathy chunks of the reg tires out now, I just can't imagine what it would due to a set of tracks. This year it just seems really bad looking at the books AND its mostly me doing it
Old 09-13-2009, 09:46 PM   #11
jomama's Avatar
Trade: Concrete & masonry
GG, go for the Bobcat Severe Duty tires! I do a lot of concrete tear-out with our S250 (probably not near as much as your doing) & have never had a flat yet. The machine was ordered new with them & now has 685 hours, tires are still about 40%. These have been the best all-around tires I've ever seen on a skid. The most wear I've seen on them was last winter when plowing snow for about 175 hours. I actually dropped the machine off on-site in November with a nail stuck in the tire, & I noticed I broke the valve stem off of that same wheel on some concrete earlier in the year. I forgot about the nail & valve stem all winter, never leaked a bit over 5 months.
To put things into perspective, I've gotten between 300-500 hours of use out of normal "Ag" tires doing the same work. It looks like I will easily see 1000 hours out of this set. Well worth the money when figuring in flats, mounting charges, traction, etc..... Anyone getting 1000 hours out of $200 ag tires isn't using the machine anywhere near what your requiring out of yours.
BTW, I carry a plug kit as Tgeb suggested, & knock on wood, haven't needed it with these tires, only another skid of ours with the ag tires. Either way, the kit was only 40-50 dollars, & is well worth the money, especially when considering down time.
jomama is offline
Old 09-13-2009, 10:10 PM   #12
Jomama THATS what I was looking for. Passion about a set of tires. My Bcat dealer has been trying to talk me into those tires for 2 months because there is 1 other HUGE demo company down her AND THAT IS ALL THEY USE. My little 185 of course had new tires and of course I have been trying to wear them out before going w another tire and I think if they kept them in stock I would have the two new ones instead of the new heavy duty tires. And your right anyone that's getting 1000 hrs out of a skid steer tire(key word skid) are not doing what I am doing. But I am convinced more then ever about using the severe tire. (pic is of a 4000 sq ft driveway tear out)
skid steer murdock Excavation & Site Work 9 05-11-2009 10:30 PM
I bought a Skid Steer Stone Mountain Decks & Fencing 62 03-17-2009 11:44 PM
New Holland LS150 Skid Steer For Sale bidsfornothing? Contractor Swap 0 01-25-2009 03:18 PM
Skid steer tires Tim Doyka Excavation & Site Work 3 01-10-2009 11:39 AM
Looking for skid steer CNC Excavation & Site Work 15 11-03-2008 06:13 PM
