Septic System
Old 09-05-2006, 11:09 PM   #1
fredIII's Avatar
Trade: home improvements
Septic System
i stepped in a sink hole in my yard, when i peeled the turf back i could see 3 pipes , 2 were about 8 inches a part as if they were connected ? then the other one looked like it was 18 inchs from the other side (coming in like a t) all stopping in this area ? this was after the d box ( by the plan )sre these pipes supose to be connected ? can i just fill this back in with sand or gravel then topsoil ?its been very wet around here too.weather wise
fredIII is offline
Old 09-06-2006, 03:10 PM   #2
fredIII's Avatar
Re: Septic System
a lot of lookers but no comments ? is this the right place to post this ?
fredIII is offline
Old 09-06-2006, 03:36 PM   #3
denick's Avatar
Re: Septic System
Fred,
Yes this is the place. You might not have hit a septic expert yet. Most guys go to bed before you posted this and they leave for work at 5 - 6 am. They don't always have time in the am to post a good reply.
Would it be possible to post a picture? It's not the kind of answer that you'd want to make a mistake on.
Nick
"Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein
denick is offline
Old 09-08-2006, 08:27 PM   #4
dirtySiD
dirtdiggencat's Avatar
Trade: M.U. contractor
Re: Septic System
does your plan indicate that you may be looking at a junction or distribution point. what type of pipe are you looking at i.e. size , color, perforated or solid, etc. ?
in my opinion, dont cover it up. it sounds like it could be a failed T or junction in the pipe at a dist point causing a short circuit of one or more sanitary field lines. this may cause the "sink hole" you mentioned and a multitude of other unseen nasty problems with your system.
call your local (city or county) ground water protection dept. person for an inspection. be prepared to call in a licensed SSD fellow after that.
i hope i'm wrong,,,,,,,,, good luck.
SiD
________________ Everyone goes home, Every night. ___________________
dirtdiggencat is offline
Old 09-08-2006, 08:35 PM   #5
jmic's Avatar
Re: Septic System
Fred,
Hard to tell without seeing it, sounds like you could be looking into the second d - box, could it have gotten broken? How far away is this from the known d - box that you know of?
Joe
jmic is offline
Old 09-08-2006, 08:38 PM   #6
jmic's Avatar
Re: Septic System
Fred,
Also if that was the last trench it could have been connected without a d - box using a "t" fitting, question is what happened to it?
Joe
jmic is offline
Installing Septic System SMKFULLER Excavation & Site Work 8 04-03-2008 09:23 PM
Living Filter Septic System jmic Excavation & Site Work 18 07-20-2007 09:31 PM
Septic system construction. gdavis Excavation & Site Work 5 02-04-2007 03:29 PM
Systems Development List Gordo Business 19 01-08-2007 07:28 PM
forced hot-water system daniem1 HVAC 1 03-02-2006 05:37 AM
