Sand VS Stone
While on the drain topic when thinking about under ground drains like a footing drain wouldn't it be better and easier to use a clean sand and pipe combination and forget about fabric and stone?
Nick |
Re: Sand VS Stone
UH, NOOO!
Don't think so Nick. Talk about major siltation.
Re: Sand VS Stone
How Joe?
Where would the silt go? What happens when silt washes down on stone? What happens when silt runs down on sand? Silt shouldn't be running on an underground drain to any degree anyway after backfill. Talk to me! Nick |
#4 | |
Re: Sand VS StoneQuote:
clog stone gets sand silty silly when ground water flows it seems to me it would take sand particles with it into pipe making it all nasty and clogged after yrs.
Re: Sand VS Stone
Joe,
Your right about the holes. I have been concentrating on the infiltration of silt into the stone and drains I have found with fabric that is sealed by silted clay material. We now cover fabric with sand wherever I have doubts about the soil conditions. Nick |
Re: Sand VS Stone
Ok and what happens to the sand when it gets all contaminated with silt?
And do you keep both feet firmly planted on the floor when you brush your teeth?
Re: Sand VS Stone
Joe,
In an underground drain where does the silt come from? Nick |
Re: Sand VS Stone
Ground water moving through soils
Re: Sand VS Stone
Underground water moving through soil only moves particles of soil when there is a void to move it through. If there are no voids there should be no silt.
There shouldn't be voids in properly placed backfill. Nick Is there anyone else out there? |
Re: Sand VS Stone
I could be wrong, but seems to me that water traveling through certain ground conditions could start bringing in particles of soil into the pipe system., creating voids and causing more problems. Am I crazy?
Vagitarian
Re: Sand VS Stone
Water will move faster through stone than sand. Also, the sand will fill in through the holes of the pipe.
Re: Sand VS Stone
YES, YES, Thanks for the support Rhino!
#13 | |
Trade: underground
The benefit of fabric around an underdrain will depend on the soil conditions. If the soil is well draining to begin with the use of fabric doesn't add much. In poorly draining soils, fabric prevents soil particles from migrating into the voids in the stone and choking the drain. |
| Stone Wall Pricing | CJKarl | Masonry | 45 | 01-09-2008 08:23 PM |
| Mortar Bedding for Stone on Concrete Question. | lukachuki | Masonry | 10 | 05-26-2007 10:09 PM |
| Advice on Precast Stone sills for Stick-on Stone | turbomason | Masonry | 6 | 03-04-2007 12:44 AM |
| How to remove cement from cultured stone? | ruskent | Masonry | 9 | 01-31-2006 04:07 PM |
