Rock And Gravel Names - Page 2 - Excavation & Site Work - Contractor Talk
Old 05-01-2015, 02:31 PM   #21
Moxley-Kidwell's Avatar
Trade: Excavation & Asphalt Paving
Rewards Points: 286
Re: Rock And Gravel Names
Originally Posted by dom-mas View Post
Right, its put at water lines to stop erosion. I suppose it could be used anywhere for erosion control but historically it's used along river banks etc...That's why I say it's not so much defined by what it is as how it's used.
Mostly erosion control, pipe out falls, pond out falls, steam banks, etc.. Around here it's classI, classII and classIII mostly. Larger the number larger the stone. Cut out the area and install nonwoven geofabric and install the stone. In extreme cases they will also grout it with concrete if there is enough water to move the stones around.
Moxley-Kidwell is offline
The Following User Says Thank You to Moxley-Kidwell For This Useful Post:
dom-mas (05-01-2015)
Old 05-01-2015, 02:39 PM   #22
GettingBy's Avatar
Rewards Points: 6,486
Probably depends on max GPM. A cu yd of water weighs 1700 lbs and if it's moving that is some kind of force. Twice the speed gives you 8x the force which is why speedboats gobble fuel.
GettingBy is offline
Old 05-02-2015, 01:36 PM   #23
Box Builder
Morning Wood's Avatar
Rewards Points: 9,166
Only terms I'm familiar with is what the local pit sells. Anywhere else the names are all different.
They have a a road base or parking base product they sell. I'd say it's 1 1/2" crushed and smaller with fines and some sand. They call it Grizzly (griz) Pack.
Morning Wood is online now
Old 05-03-2015, 01:47 PM   #24
Vagitarian
rino1494's Avatar
Rewards Points: 2,388
1B or #8 is pea gravel like they use under superior walls
2B or #57 is 3/4 clean gravel that is used under slabs and for drainage. The washed 2B is used in concrete.
2A modified is is 3/4" minus with fines. Used for road base before paving, driveways, pipe bedding, and structural fill.
#3 stone is clean crushed rock that is about softball size. Used for construction entrances, driveway base and gabion baskets.
#4 stone is clean crushed rock that is baseball size.
R-4 rip rap is rock that is the size of basketballs. Used for rock outfalls at the end of discharge pipes, slope stablization, storm water channel lining, river bank stablization.
R-5 rip rap is about the size of beach balls.
R-8 rip rap is about the size of volkswagons. We hauled a bunch of R-8's to a contractor that was doing a bridge across a river. They used it to build a causeway across the river. One other truck ripped his tail gate right off dumping it and it fell into the river. Luckily the excavator operator was right there and fished it back out.
rino1494 is offline
The Following User Says Thank You to rino1494 For This Useful Post:
Seven-Delta-FortyOne (05-05-2015)
Old 07-13-2017, 02:09 PM   #25
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 630
OLD THREAD WARNING!!!!
I just found this. It's short, but interesting.
It's a free download.
http://www.braenstone.com/stone-grad...tone-grades%2F
Delta
hdavis (07-13-2017)
Old 07-13-2017, 05:15 PM   #26
ismaels's Avatar
Trade: concrete flat work
Rewards Points: 78
I wonder what God called the different types when the world was created or what words Eskimos have for it...oops that would be ice wouldn't it. Check this out http://www.braenstone.com/2017/05/crushed-stone-grades/
ismaels is offline
Old 07-13-2017, 06:20 PM   #27
Trade: Builder/GC
Rewards Points: 630
That's the same link I posted.
Delta
Old 07-14-2017, 10:48 AM   #28
TimNJ's Avatar
Rewards Points: 3,146
We have "clean" which would be only the size....3/4 clean is just 3/4.
Then we "blends" which would be the size and less....3/4 blend nothing bigger than 3/4, but smaller crushed mixed in it.
TimNJ is offline
Old 07-20-2017, 11:15 AM   #29
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
Rewards Points: 864
Where I work (a rock quarry), we use these names........
2" clean = #4 Railroad ballast or just #4
1 1/2" clean = 57s
1" clean = 67s
3/4" clean = 7s
1/2" clean = 8s
1/4" minus = 10s
1 1/2" minus (or "blend" or "base") = 610s
1" minus (or "blend" or "base") = DGA (Dense Grade Aggregate)
There are more within each size, depending on the spec the customer wants. The specs come from the ASTM manual...
...uhh, it's a pretty dry read, so just take my word for it
EDIT: Got me with the 2 year old thread....dammmmmmit.
Jim P.
jproffer is offline
The Following User Says Thank You to jproffer For This Useful Post:
Seven-Delta-FortyOne (07-20-2017)
Old 07-20-2017, 05:41 PM   #30
Trade: Builder/GC
Rewards Points: 630
1 1/2" clean = 57s
1" clean = 67s
3/4" clean = 7s
1/2" clean = 8s
1/4" minus = 10s
It's all good. I'm still interested in hearing about local variations for gravel grades.
Delta
jproffer (07-21-2017)
Rock Excavation Tom Konan Excavation & Site Work 0 01-27-2014 11:13 AM
gravel clasifications hottyhoo2012 Construction 9 02-02-2013 02:31 PM
Wet basement, just making sure my thoughts are correct HandicappedHome Excavation & Site Work 7 10-12-2012 06:17 AM
pea gravel (rock finish) pre-reno Concrete & Paving 19 05-19-2010 10:45 PM
Gravel over sand driveway Teetorbilt General Discussion 5 12-31-2009 08:45 AM
