RIM GUARD , TRACTOR TIRE FILL Liquid
Old 04-08-2007, 11:38 AM   #1
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Have a 2 wheel drive full size backhoe. Would You suggest filling the rear tires? Will be used for footers septic ect. Are tires usually filled for farm work only ? How do you tell if tires have liquid? thank's Drift
Driftwood is offline
Old 04-08-2007, 06:36 PM   #2
TMatt142's Avatar
Re: RIM GUARD , TRACTOR TIRE FILL Liquid
Boy, I've never heard of putting fluid in the tires of a backhoe. I know it's usually done for added weight (which I would think you don't want). The only other tire advice I can give for backhoes is stay with bias ply tires, never put radials on.
TMatt142 is offline
Old 04-08-2007, 11:05 PM   #3
backhoe1's Avatar
Trade: excavating contractor
Do you have traction problems? Generally if you aren't having problems with the tires spinning then you wouldn't have any need for fluid in the tires.
backhoe1 is offline
Old 04-08-2007, 11:13 PM   #4
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
I use to work on a farm when I was a teenager. I thought what we filled them with was to prevent damage to the tire. All I really remember is that they were a pain in the butt to change.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company.
dougchips is offline
Old 04-09-2007, 09:12 AM   #5
fhdesign's Avatar
Trade: Construction, Landscaping
It really depends on the machine, some machines will have noticeably better traction and stability, especially while doing loader work. Now when it comes time to repair a tire, it's more difficult so it usually cancels out any benefits.
fhdesign is offline
Old 04-09-2007, 09:54 AM   #6
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Thumbs up
In the learning stage, I'm a greenhorn in this area ! Nice to have have
a helping hand here . I read tractor net. and there application is usually
farming. That's where this brain fart germinated
Old 04-09-2007, 09:31 PM   #7
TMatt142's Avatar
Fluid won't necessarily give you more traction if it's in your tires. What I learned on 2wd backhoes to keep from spinning the tires is ride your brake a tad when going into a pile and that'll keep the wheels from spinning. Just let off of the brake a bit when your breaking out with a bucket.
TMatt142 is offline
Quickest, best way to fill prefinished hardiboard trim nailholes? pinesol Painting & Finish Work 8 07-31-2007 07:47 AM
Help!!!! with Red Guard!!!!! ReallyConfused Ceramic & Stone Tile 2 03-14-2007 03:51 PM
Flowable fill? ruskent Excavation & Site Work 18 01-16-2007 06:37 PM
Slab on Grade fill options? James Ellis Construction 10 10-24-2006 01:55 AM
Wood fill for cabinets Tornado65 Carpentry 2 11-02-2005 08:17 AM
