Riding Arena
Old 01-25-2007, 03:06 PM   #1
Excavating Contractor
Jerry Hill's Avatar
Trade: Excavating
Riding Arena
I have been asked by a customer to build her a riding arena. It will be 100x100. I have found some information in the internet which is helpful.
The area is low soi I thought I would start by building a shallow ditch around the outside and moving the material into the center for drainage. the adding 6 or so inches of sand on top.
I was wondering if any of you have built one and if you have any tips or advice.
Jerry Hill is offline
Old 01-25-2007, 05:30 PM   #2
tgeb's Avatar
Re: Riding Arena
Hi Jerry, Welcome to the site.
I have never built an arena from "scratch" but have been around a few that were under construction. Have added footing to, and regraded a couple. And my kid rides in pony shows so I have personally seen many.
You are correct about cutting a drainage swale around the perimeter, nothing worse than a wet riding ring. What you may have to do though is dispose of any wet or non-compactable soils and import some that will create a good solid base.
Not unlike any other building pad or roadway that we might construct if you have a soft base you will end up with problems.
Other than that, nearly every riding ring I have seen and all that I have personally worked on had at least 6" of compacted crushed run as a base then capped off with 4" or so of sand.
Some rings have a specialised footing material but most are just sand.
Here is a link to an article that describes riding ring construction that you will certainly find helpful.
http://pubs.cas.psu.edu/freepubs/pdfs/ub038.pdf
Post back with any specific questions that you might have and I'll see if I can help you out. I have a friend that has built a few rings and I can always call him and pick his brain.
www.gebcon.com
Last edited by tgeb; 01-25-2007 at 05:32 PM. Reason: What the hell is the thumb of Michigan?
tgeb is offline
Sunday is Good Riding Weather! Finally! Ed the Roofer Off Topic (Non Trade) 0 04-28-2007 12:54 AM
Motorcycle Madness ron schenker Off Topic (Non Trade) 66 08-22-2006 04:17 PM
Riding the beam ? dirtdiggencat Excavation & Site Work 30 08-02-2006 08:47 PM
Rodeo / Arena Lighting questions norcal5.3 Landscaping 4 02-18-2006 06:47 PM
