Trade: excavating contractor
Replacing Tee
I've been asked to bid a job that requires replacing a 6"x6"x2.5" tee with a 6"x6"x4" tee in a PVC water main. Question I have is do most people use some kind of a repair coupling etc. to help in replacing fitting? Any feedback is appreciated.
Re: Replacing Tee
call scott at 605-432-4594 tell him you need 2-6" repair couplings...the type with no center stops in them. or DSG or whoever you buy stuff from. cut existing pipe about 18" away from existing tee on both sides...remove/trash tee...bevel all pipe ends. put new tee in with your makeup lengths of 6" and drive repair couplings all the way onto the pipes you put into the tee to fit the piece you took out...leave about 1- 2" short in length, so you have room to get it in there. lube the hell out of the pipe and gaskets, take a block of wood, and 2lb. hammer and bar....and tap the repair couplings back onto the existing main. just make sure you measure/mark where your gap is going to be on both sides so you know you have the couplings on the proper distance. same thing going to your 2.5"...you just may have to get some reducing bushings to get down to that from 4"
someday, i'll be as patient as Nick. |
Vagitarian
Re: Replacing Tee
Yeah, like day said. They make repair couplings that slide over the pipe. Like Day stated, you need to lube them up good and don't beat on the coupling with a hammer. If you eat your wheaties in the morning, you can slide it over the pipes by hand.
Trade: Plumbing & Gas Contractor
Re: Replacing Tee
Repair couplings are no longer allowed in the IPC ,there must be a stop because too many people are not aligning the repair coupling properly.
Re: Replacing Tee
Thanks guys, that's what I was looking for!
#6 | |
Re: Replacing TeeQuote:
when did this happen? all the water districts and contractors here still use them...a LOT. certain to leak "certainteed"...still makes em http://www.certainteed.com/NR/rdonly...hure402449.pdf harco still makes em http://www.harcofittings.com/documen...irCoupling.pdf in fact backhoe1...the certainteed link has instructions and some photos that may be helpful
someday, i'll be as patient as Nick. Last edited by dayexco; 06-05-2008 at 04:07 PM. |
Trade: site work
Re: Replacing Tee
The easiest way to do it is using Dresser couplings the rubbers and everything are with them they are easy to use and make a job like this fast besides that they are about half the length of a solid sleeve making it easier to work in a tighter area.
Re: Replacing Tee
who likes spinnin bolts when you can use a hammer?
#9 | |
Of course saddle valves are not legal either but try shutting down a city main so you can cut in a wye,they won't let you, and they deem the saddle valve legal for that connection. |
Trade: Excavating
Re: Replacing Tee
try "hymax" couplings these things are awesome when it comes to repair couplings! Also the last time i checked governing authority over water mains was not any kind of plumbing code at all but AWWA and Ten States Standards. The plumbing codes govern private works not municpal such as water sewer and storm.
| Replacing Piece of Laminate on Floating Floor | Spencer | Flooring | 13 | 12-06-2008 08:40 AM |
| Replacing Asphalt Speed Bumps | lukachuki | Concrete & Paving | 2 | 05-27-2008 11:28 AM |
| Replacing posts that go through patio slab | jackdumas | Decks & Fencing | 11 | 03-24-2008 04:31 PM |
| Replacing glass blocks | recruit4meisner | Remodeling | 6 | 01-12-2007 08:21 PM |
| Replacing Old 2 wire receptacles | steveprichard | Electrical | 11 | 04-22-2006 07:25 PM |
