Replace My Barn W A Steel Buliding
Old 02-09-2007, 05:25 PM   #1
ctkiteboarding's Avatar
Trade: excavation and tree service
ok my barn is shot and small, im looking to replace it with something steel and inexpensive,,
it has to be similar in footprint but i hope to be able to get a higher roof line and large doors , does anyone have a steel shop and did u install it ,, how big and how much any info would be great thanks in advance
ctkiteboarding is offline
Old 02-09-2007, 06:50 PM   #2
dayexco's Avatar
Re: Replace My Barn W A Steel Buliding
what you need to do is PM joasis, he does that for a living, and has a wealth of knowledge in this
dayexco is offline
Old 02-10-2007, 02:50 PM   #3
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
We have a 40x80 pole barn. The celing inside is 18ft. We had it installed for $60,000. That was about 10 yrs ago. We then insulated it, installed a bathroom, heat and concrete floor. We are planning on adding on to it soon. One of the best ways to go IMO.
rino1494 is offline
Old 02-10-2007, 05:21 PM   #4
im hoping for a 30 by 60 w 12 foot doors
Old 02-10-2007, 05:30 PM   #5
ruskent's Avatar
Trade: Outdoor D/B
Make sure you build it big enough!! Figure out what size you need a double it! You will always run out of room!
ruskent is offline
Old 02-10-2007, 05:35 PM   #6
i have to stay close to my original structure ,im hoping to get abit more space and alot more head room for 12 doors
Old 02-10-2007, 06:11 PM   #7
dayexco's Avatar
you'll regret it if you don't go w/at least 16' sidewalls so you can put in a 14' door. nice sometimes to back a semi in should you have to. your floor costs the same, the roof costs the same, just a little more for sidewall material
dayexco is offline
Old 02-10-2007, 06:18 PM   #8
tgeb's Avatar
I did a Google on "steel buildings" and got a ton of leads, most have no pricing info but this one had some.
http://www.olympiabuildings.com/Clea...-buildings.asp
Not the exact size you are looking for but could give you an idea of what's out there.
Have you tried to PM Joasis, he builds steel buildings and seems like the kind of guy that would help you out if he could. Maybe steer you away from bad products etc.
www.gebcon.com
tgeb is offline
Old 02-10-2007, 06:31 PM   #9
yes i just chatted w/ him ill have to make some calls this week,, i will try to get as much head room as possible , foot print cant change too much but the height i hope can be worked out
Old 02-15-2007, 09:34 PM   #10
BoydS's Avatar
Trade: Electrical Supervisor
I too have been looking into installing a steel building and have done quite abit of research. There are several good manufactures out there, and I have looked at many. I will say that Mueller and Whirlwind both are good quality buildings and many more I am sure. You can do a google search for their websites.
There are many things to consider when you spec out a steel building. Wall height is very important as was mentioned. Typically your overhead door will be 2 foot shorter than the wall height, depending on if its on the end or side wall. It all depends on the purpose of your building. Then there's insulation, maybe skylights, windows, etc. Take your time, there are many things to consider and get several quotes, this is a major investment.
Good luck...
BoydS is offline
Old 02-16-2007, 08:04 AM   #11
joasis's Avatar
I had an interesting conversation with a potential customer yesterday. He had quotes from two different erectors on buildings, clear spans, and a 50 wide by 60 long was 36k, but a 50 wide by 120 long was 95k.
He could not understand how, when it appeared to him it should be cheaper. So for you guys reading this, clear span buildings, like the one pictured in my red iron posts, have main frames...cheaper buildings will use one frame for up to 60 feet of length, and build the end walls from purlin and light steel collumns...since they carry only half the load of the main frame. So the cheaper building has one frame, the long building would have 4 or 5 depending on engineering...
Anyway, I think I will get the bid, and I don't skip frames, I prefer a full framed building, may cost more, but you get what you pay for.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
glass coated steel haskl33 Excavation & Site Work 3 10-23-2007 11:33 AM
Steel pole barn pricing. DeanV Painting & Finish Work 6 06-22-2007 09:34 PM
Pole Barn Feeder sparkysteve Electrical 4 10-21-2006 08:57 PM
Tinning a barn??? Bradracer18 Roofing 15 04-06-2006 08:44 AM
Can I replace a W8x35 x 20 foot steel I beam with... Ray General Discussion 8 03-20-2006 03:38 AM
