Removing A Tennis Court
Old 12-30-2008, 06:16 PM   #1
72chevy4x4's Avatar
I'm looking at removing a tennis court totaling 15k sqft, filling with topsoil and hydroseeding.
Would typical construction be a 4" base with 2" of asphalt on top? When pulling up the asphalt, gravel sticks to or is interlaced w/ some of the asphalt-will asphalt recyler's accept the gravel/asphalt combination or do they typically prefer 'clean' asphalt?
72chevy4x4 is offline
Old 12-30-2008, 06:48 PM   #2
tgeb's Avatar
Re: Removing A Tennis Court
In most instances, I would think the recycler would accept the material you are removing, (asphalt & aggregate), as long as there is no soil mixed in with it.
For specifics, you will have to make a phone call to the local plant to be sure.
www.gebcon.com
tgeb is offline
Old 12-30-2008, 06:49 PM   #3
mickeyco's Avatar
Trade: Squirrel Handler
Toss it in the neighbors yard.
mickeyco is offline
Old 12-30-2008, 07:48 PM   #4
Midnight
Blas's Avatar
Trade: Excavating, Grading, Demolition, Underground Utilities
Is the pavement rubberized or coated with epoxy or paint? Does it look like it was overlayed? You can look at the outside edges of the court to determine thickness. I have run into problems with crushers not accepting Bituminous with the rubber/paint/epoxy on it. I have also run into tennis courts that have been overlayed.
"It is what it is"
Blas is offline
Old 12-30-2008, 09:31 PM   #5
john1066's Avatar
Trade: site work
we have just the machine for that job it takes whole parking lots and makes it into a recycled product. weve done tennis courts parking lots cart paths roads and also havea 4' wide drum so we can do trenches
john1066 is offline
Easily removing Wallpaper !!!!!YUCK!!!!! PaintedLady Specialty Coatings 13 04-19-2011 06:32 PM
tool for removing shingles 72chevy4x4 Roofing 30 09-18-2009 02:00 PM
removing load bearing wall question. auctionimage2 Construction 6 12-19-2008 01:41 PM
removing doorway from solid masonry wall Jamison Remodeling 3 08-15-2008 06:23 PM
Tennis Court Demolition Falling Water Excavation & Site Work 15 06-11-2008 11:01 AM
