Removing Old Asphalt From Paver
Old 05-07-2008, 08:25 PM   #1
Tim Doyka's Avatar
Trade: Ultility Contractor
I need to remove asphalt from a paver to replace a conveyor belt underneath it. I was wondering if a steam cleaning would help or some chemical might soften up the hardened asphalt. The hopper is not full or anything like that just built up on the rollers and on the sides. I have a lrge propane torch but the belt rides on wood slats and I am tired of burning my arms any help? thanks Tim Doyka
Tim Doyka is offline
Old 05-07-2008, 08:42 PM   #2
Handle It!
MALCO.New.York's Avatar
Re: Removing Old Asphalt From Paver
Gasoline. Be UTTERLY careful and remove the battery!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 05-07-2008, 09:15 PM   #3
tgeb's Avatar
I would NOT use gasoline. You could end up in the Hospital.
I would consider spraying it with diesel fuel and let it soak a while. Heat from the torch is probably the quickest way.
Put on a coat so you don't get burned.
www.gebcon.com
tgeb is offline
Old 05-08-2008, 06:02 AM   #4
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
Mexicans
rino1494 is offline
Old 05-08-2008, 07:40 AM   #5
Handle It!
Yes ! Diesel is a much better solvent to use!
Old 05-08-2008, 09:16 AM   #6
Captain of the Titanic
Vinny's Avatar
Trade: Asphalt Paving,Excavating, Masonry
I have used some of the more enviromentaly friendly products like concentrated orange based solutions. You can apply it straight and its as good if not better than diesel fuel and almost as good as gasoline with out the explosive consequenses.
The use of a release agent (like deisel) and a torch is definitly the fastest way but I have never heard of a paver with wood slats. Obviously a torch would be bad for that.
Roccies Asphalt Paving
The Right Way Driveway Company
If you say you cant, your a loser. If you say you wont, your a quiter. Which one do you want to be?
Vinny is offline
Asphalt over plywood ??? Leedo Concrete & Paving 6 03-19-2008 08:46 PM
Owens corning a solid strip of tar nolo Roofing 26 01-29-2008 01:25 AM
Cutting Asphalt Help lukachuki Concrete & Paving 15 05-21-2007 11:26 AM
Is there a consensus about shingles? PipeGuy Roofing 41 12-29-2004 12:49 AM
Removing stain from a french door or replace? Mike F Painting & Finish Work 6 03-22-2004 10:46 PM
