PVC Pipe Tool Box
Old 04-23-2006, 09:59 PM   #21
jmic's Avatar
Re: PVC Pipe Tool Box
Toothbrush?
Joe
jmic is offline
Old 04-23-2006, 10:07 PM   #22
PipeGuy's Avatar
Trade: underground
Originally Posted by rino1494
For storm drain pipe, we use a chainsaw.
How do the chains hold up? How long does it take to cut an 18" pipe? 30"? I was told the chains are very short lived so I've steered clear of buying one. But somehow we're managing to waste diamond cut-off saw blades like foam ear plugs and I'd really like to hear from somone who's using the concrete cutting chainsaws on how they're working out.
PipeGuy is offline
Old 04-23-2006, 10:18 PM   #23
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
The storm drain pipe that I am talking about is the double wall corrugated.
rino1494 is offline
Old 04-23-2006, 10:23 PM   #24
PipeGuy's Avatar
Trade: underground
Originally Posted by dayexco
we use our stihl chop saw...we don't keep many tools in our pickups. we pull a 20' cargo van where we keep all our fittings,pipe, tools, etc. we use the old style carpenters wood tool boxes. for services...
ditto
by the way, what brand sewer lasers you guys running?how do you guys handle your air in sewer lines?
We have a Leica (Laser Alignment) 6775 green beam and bought a Mikrofyn MLP 120 last year. We have not had good service from the Leica. It needs calibration as much as every other month and seems to be in the shop constantly. The Mikrofyn was less expensive than the Leica and has provided good service but when the guys lost the remote last month it was $500 to replace. Also, Mikrofyn doesn't make a 'drop bar'.
We haven't come up with a standard for ventilating. I bought a 120V blower last year that can be set in the manhole and directed up the pipe barrel but it means running a generator all day. We really struggle for a consistent grade when the air gets screwy. At .500% grade (or maybe even less) the effects of refraction can cost a lot of money. What kind of voltage does the frunace blower use?
PipeGuy is offline
Old 04-23-2006, 10:25 PM   #25
PipeGuy's Avatar
Trade: underground
Oops...my bad. A chainsaw huh? What kind of cut do you get on HDPE? Is it ragged?
PipeGuy is offline
Old 04-23-2006, 10:31 PM   #26
dayexco's Avatar
110. it's the ****s, but have to run little honda gen there to operate it. we shove enough air thru the main to typically blow out a match on the other end. after about 450', you'll sometimes get a beam "dance"....but nothing too severe. we do, but i get reluctant to go much more than 5-550' with our laser
dayexco is online now
Old 04-23-2006, 10:33 PM   #27
PipeGuy's Avatar
Trade: underground
Originally Posted by denick
Anybody already have one you think works. Any tool adaptations or suggestions.
For fixing glue joints in wet conditions. Oatey's Rain-R-Shine blue cement is a must - can't be beat for wet applications.
PipeGuy is offline
Old 04-24-2006, 07:51 PM   #28
denick's Avatar
How good is anybody at making square cuts on PVC with a hand saw?
Nick
denick is offline
Old 04-24-2006, 07:52 PM   #29
jmic's Avatar
Me,ME,ME I am.
Joe
jmic is offline
Old 04-24-2006, 07:55 PM   #30
denick's Avatar
Joseph, You am What?
Nick
denick is offline
Old 04-24-2006, 07:57 PM   #31
jmic's Avatar
Nick
I can!
Joe
jmic is offline
Old 04-24-2006, 09:11 PM   #32
Vagitarian
rino1494's Avatar
Nope, works pretty good.
rino1494 is offline
Old 04-24-2006, 09:11 PM   #33
Vagitarian
rino1494's Avatar
Nick
Who uses and handsaw anymore
rino1494 is offline
Old 04-24-2006, 09:12 PM   #34
tgeb's Avatar
Hey Pipeguy, I have a Partner K950 Chain saw.
It works very well, but you are correct the chains do not seem to last very long.
And the chains for the Partner start at like $500 and go up. Plus the bar has to be replaced about every 2 chains, $150.
I have a cutting job this week in Kensington, I ordered a backup chain and bar, (cause this chain is about done), My diamond blade supplier talked me into a chain that has twice the segments as the typical chain. Chain and bar $800, they claim 30% better life. We'll see.
I have never tried it out on RCP but I am sure it would make quick work of it. and the chain may hold up better than a diamond wheel.
When I use it we are cutting concrete walls, minimum 8" thick and the chain wears pretty fast.
Thinner material like RCP would not wear the chain as fast and could be comparable to a diamond cut off blade.
I will tell you it is easier to handle with out the GYRO forces you get with a cut off saw.
I chose the Partner over the ICS because of Partners rep with cut off saws and chain saws in general. I don't know if one is better than the other.
Oh, one more thing, Thing1, you must have running water to keep the chain cool and clean. It cannot "run dry".
www.gebcon.com
tgeb is offline
Old 04-24-2006, 10:20 PM   #35
PipeGuy's Avatar
Trade: underground
What're you doing...putting in a basement door?
PipeGuy is offline
Old 04-25-2006, 06:35 AM   #36
tgeb's Avatar
No not this time, have done a few with this saw though.
This one is tearing down an existing addition that looks like it was originally a screened porch. A raised foundation, with slab, then sleepers.
Funny thing with this slab, when it was poured there was no band board on the first floor framing.
They put blocking inside, between the floor joist, and poured the slab over the foundation wall and into the joist area. I want to cut the slab free from this before demo-ing the slab.
The Lady is real freaked out that we will crack tile in her new basement bath. Seems like the best way to get it done.
Then we'll do footings for a slightly larger addition in the same area.
www.gebcon.com
tgeb is offline
Drain Pipe denick Excavation & Site Work 18 07-12-2009 04:41 PM
Gas Pipe Question.... drbigfresh Plumbing 9 02-28-2007 03:51 PM
Using Flex Pipe dirt diggler Pool Construction & Enclosures 8 02-25-2007 04:30 PM
How to trace gas pipe? karma_carpentry Carpentry 15 11-30-2005 11:47 AM
Pipe assembly tool mdshunk Tools & Equipment 9 08-06-2005 10:40 AM
