Price Per SF Demo 5" Concrete Floor?
Old 04-25-2006, 06:59 PM   #1
Nac's Avatar
Trade: Concrete, masonry & excavation
Was woundering what you guys are getting to demo & remove concrete slab. I was asked to bid a 31,500 SF warehouse floor the floor is elevated 4' above the parking lot. 2.00 a Sf is what i normally charge but it is a high volume job should i discount it a bit?
Nac is offline
Old 04-25-2006, 07:08 PM   #2
PipeGuy's Avatar
Trade: underground
Re: Price Per SF Demo 5" Concrete Floor?
How long will it take? What're my daily costs? What other expenses will I have? What unusual or less than obvious risks am I taking? How much profit do I want to earn? All those divided by the quantity.
That's how I figure unit costs regardless of the scale of the project.
PipeGuy is offline
Old 04-25-2006, 07:32 PM   #3
Wolf's Avatar
Trade: demolition
Charge all that the market will bear. Why discount???
Wolf is offline
Old 04-25-2006, 07:33 PM   #4
joasis's Avatar
More info needed...like what does it cost to get rid of? Steel in it? Hydraulic hammers needed? Or can a trackhoe rip it out?....I have seen concrete we could breakout with a Bobcat...and some you had guys with 120lb jackhammers on...lots of variables.
joasis is offline
Old 04-25-2006, 07:42 PM   #5
Nac's Avatar
Well to get rid of it it would cost 600 a dat for a triaxle dump + 150 a load and a recyling plant is about 2Mins away. Or I could get 20 cy containers at 300 ea but that would cost more. There is min wire mesh inside the slab not sure if there is rebar. The slab is cracked heavily in between the colum lines it has doped as much as 8". I was actually thinking bringing my PC-45 with a 900lb Hammer to reduce it and then rip it out and load it with a skid steer or a small loader. The other thing is to bring in a crusher to make 3/4"- RCA and use it as base.
Nac is offline
Old 04-25-2006, 07:49 PM   #6
jmic's Avatar
I'd think the crusher would make the most sense, do you own that one shown in the pic post?
Joe
jmic is offline
Old 04-25-2006, 07:57 PM   #7
Nac's Avatar
None it was rental (operator & Machine) from a local contractor. 3,500 for the day. I am looking into buying a compact crusher I have to run the number to see if it is worth it. Here is alink to the compact crusherhttp://www.globalplant.co.uk/new_equ...ed_crusher.htm The machine is a Guidetti MF520 15,432 lbs, will crush 25 tons an hr, has an imput size 20"x24" and cost 98,353.00 US dollars
Nac is offline
Old 04-25-2006, 08:01 PM   #8
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
I don't think that mini crusher is worth the cost for the output that it will produce.
rino1494 is online now
Old 04-25-2006, 08:01 PM   #9
denick's Avatar
Nac,
How much room do you have in the parking lot?
What is the access to the building?
How open is the inside?
What height clearance?
Interior or exterior obstacles?
Nick
denick is offline
Old 04-25-2006, 08:04 PM   #10
jmic's Avatar
Nac,
Get the job set up and then get the machine there for a demo looks nice and compact. Have you ever seen the crushers that are like a bucket and go on an excavator, crush a bucket at a time. I'd like to see that in action.
Joe
jmic is offline
Old 04-25-2006, 08:06 PM   #11
Nac's Avatar
You have a colum about every 30' apart and probably 20' hiegh ceilings. There warehose is empty no ubstuctions. the floor is 4' above finsh grade and the only access is threw standard 8' wide loading dock doors one wall has 10 doors. You have 100x 50 parking lot on one side and 250 x 30-40 on the side where the loading docks are.
Nac is offline
Old 04-25-2006, 09:11 PM   #12
denick's Avatar
Nac,
I had asked the questions about room to see if it was possible to haul in 60 - 80 yards of material to make a ramp so that you can access the interior easier and handle the material less.
At 31500 sf and 5" thick it looks like 485 cy of material in place. We always figure 60% more yardage for broken concrete. If the floor has sunk 8" can you use the crushed material as base to level up the floor? With the mini crusher can it be processed inside and put right back down?
We have with our Bobcat and 250LB hammer gone in buildings and broken floors in place. Taken the hammer off and with the thumb backed the truck in and load out in a reverse direction with great success.
Nick
denick is offline
Old 04-25-2006, 09:13 PM   #13
dayexco's Avatar
man, you dudes out east make big money...here to pull a 4-6" floor/drive...with any volume, goes for about $1.10 a sq ft.
dayexco is online now
Ceramic tile over concrete floor Handyman62010 Flooring 14 03-15-2007 09:40 PM
Hardwood floor on concrete basement? georgia dawg Flooring 5 07-13-2006 12:14 PM
