Trade: gc
Pouring New Concret For A Existing Sidewalk
Hi,
i have a job im bidding on and wanted some advice, i have done small concret jobs before but this is about 6x100 ft sidewalk but i have bever formed a job like this before and never used expansion joints before and what the proper installition method is the curb will not be removed, thanks in advance |
Trade: excavating contractor
Re: Pouring New Concret For A Existing Sidewalk
What is the question?
| The Following User Says Thank You to backhoe1 For This Useful Post: | tgeb (10-06-2009) |
wtf?
someday, i'll be as patient as Nick. |
| The Following User Says Thank You to dayexco For This Useful Post: | jmacd (10-06-2009) |
Professional Instigator
Should he cash the check knowing fully well that he is going to F*** it up???
| The Following User Says Thank You to rbsremodeling For This Useful Post: | jmacd (10-07-2009) |
I like Green things
It's just concrete, he'll be fine.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana Warner Remodeling Facebook |
Trade: General contractor
It turns white, gets hard and cracks
Is this a city sidewalk?
In the cities I have put is sidewalk, they all had specific rules on how they wanted it done, expansion joints, etc. So call them for specs, and you will need expansion joint material between the walk and the curb and gutter, and every ? feet in the walk. Next hire a finisher that is experienced with city walks, and can set the forms. Now you will find out that the finisher, the concrete supplier, and the other material suppliers made money. But not you, at least you will get some experience and learn a lesson. |
#8 | |
Midnight
Trade: Excavating, Grading, Demolition, Underground Utilities
Re: Pouring New Concret For A Existing SidewalkQuote:
"It is what it is" |
Fentoozler
Just mix it up in buckets and pour as you go.
Since this is the most vague question, i'll just give some tips real quick. If the walks are 4" thick then just use your 2x4's on one side of the pour setting it to get your required crosspitch if allowable. Install expansion joint on curb side for the full length of the pour leaving the top of the expansion about a 1/4" higher than the top of the back of the curb so as to not trap water after poured. Codes will dictate how many feet in btw each joint you need to put the expansion joints perpendicular to the curb.
Commercial Construction, Central Jersey |
By the time you buy the material needed to form this job as well as research the specs, you might find you would be better off hiring professionals who already have all the materials and equipment needed to do the job.
If you are the "gc" on this job (as listed on your profile), you must have a concrete contractor that you have used before or at least heard of someone local. They will know how to work with expansion joints, provide reinforcements/rebar or mesh and size it correctly, observe the slump test, order the right mix and admixtures, etc. I wouldn't bite this one off yourself.
220...221...whatever it takes! |
| Existing addition on slab drainage problem | dberkey1 | Construction | 4 | 08-21-2009 06:41 AM |
| Existing Conduit to New Enclosure | Bubbles | Electrical | 20 | 07-20-2009 05:09 PM |
| Block wall under existing roof/ceiling... | StPete727 | Masonry | 38 | 07-12-2009 08:57 PM |
| Pouring new driveway on top of old driveway | Brock | Concrete & Paving | 8 | 12-01-2008 04:39 PM |
| Tying into existing roof | Milhaus | Framing | 9 | 11-06-2008 12:03 PM |
