Oil Tank Removal
Old 07-08-2009, 07:47 PM   #1
Alwaysconfusd11's Avatar
Oil Tank Removal
Parents had there underground oil tank removed, tests showed potential leaking...and boy did it
The complany sent the cutest little machine out to pull the tank...didnt have the balls.
They ended up cutting it in half to get it out.
Alwaysconfusd11 is online now
Old 07-08-2009, 09:32 PM   #2
woodchuck2
woodchuck2's Avatar
Re: Oil Tank Removal
Yup, cutting it in half will definitly make it leak what might be left in it. That machine is a monster too, might be a litle overkill.
woodchuck2 is offline
Old 07-08-2009, 09:41 PM   #3
with the size of the holes in the tank it didnt make a difference, and the tank was cleaned before the bottom was cut.
They sent a full size equipment trailer for the little guy, they had to make a plywood ramp bc the trailer ramps wouldnt go close enough together.
Old 07-08-2009, 10:27 PM   #4
tgeb's Avatar
That little excavator ain't big enough to pick my nose, let alone pick up that fuel tank. What were they thinking?
www.gebcon.com
tgeb is online now
Old 07-08-2009, 10:28 PM   #5
Apparently they were told the tank was shallow and much smaller.
Old 07-08-2009, 11:24 PM   #6
Where's my coffee?
HanerEnterprise's Avatar
Trade: General Contracting - A/V Integration
At least the boys had a good time!
I never give up!
HanerEnterprise is offline
Old 07-09-2009, 07:20 AM   #7
JonM's Avatar
That tank couldn't have been empty if they couldn't lift it out...I've taken a couple of them out with a com-along...Tanks don't weigh all that much....
JonM is offline
Old 07-09-2009, 07:35 AM   #8
Trust me it was empty....They couldnt lift it bc the machines arm could not dig deep enough around the parameter of the tank.
Old 07-09-2009, 10:14 PM   #9
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
Better off using a shovel.
rino1494 is offline
Old 07-10-2009, 09:55 AM   #10
rustyjames's Avatar
Really. Instead of a mini do they call that class of excavator pocket?
rustyjames is offline
Old 07-10-2009, 06:08 PM   #11
Williams Ex Co's Avatar
Trade: Excavation, land clearing, sewer/water
Maybe when it grows up it can be a mini excavator....
Williams Ex Co is offline
Old 07-10-2009, 06:22 PM   #12
dayexco's Avatar
does your mommy know you have your tonka toys outta the sandbox?
dayexco is online now
what kind of tank do i need wlf89 Plumbing 4 05-11-2009 11:27 PM
Buried 250 gallon propane tank genecarp Plumbing 3 04-26-2009 07:30 AM
Septank Tank Separation Distance Aggie67 Plumbing 3 04-20-2009 08:04 PM
Addition built on top of septic tank KevinA General Discussion 20 04-02-2009 08:16 PM
Septic tank install help metzade Plumbing 6 09-26-2008 09:47 PM
