Need Some Experinced Advice On Water Line/HDPE Project
Old 07-06-2009, 08:56 PM   #1
js1579's Avatar
Trade: Utilities, Erosion control
Thanks for looking at my question. This will sound like a dumb question to some of you but I have not done one particular part of this before., I am planning on bidding on a project involving running a 10 inch pvc water line, no troubles there. However, there is a requirement to run a 400 foot HDPE encasement under a wide creek. What is the best process used to run the 10" pvc through the HDPE. 400 feet seems like a long way to push pvc through fused HDPE from one end. Also sounds like alot of electrofusion couplings. Will the entire trench need to be exposed. Any positive advice will be greatly appreciated
thanks
new poster
js1579 is offline
Old 07-06-2009, 09:05 PM   #2
tgeb's Avatar
Re: Need Some Experinced Advice On Water Line/HDPE Project
Welcome to the site.
I have no clue, sorry.
Maybe one of the other guys will have some advice.
www.gebcon.com
tgeb is online now
Old 07-06-2009, 09:59 PM   #3
Stud
Upchuck's Avatar
Trade: Excavation
I don't have any answers only a question. What are the main differences between installing 8" DI water line vs. 8" PVC water line.
Seems to me that you will have to push the pvc thru. I'm sure the more experienced guys will have an answer for you.
Upchuck is offline
Old 07-06-2009, 10:10 PM   #4
D-Excavator's Avatar
Trade: Land Clearing-Site work
I would start with speaking to the manufacturer. Seems as if they always have some hot-rod gagdet that may help you.
D-Excavator is offline
Old 07-07-2009, 05:31 AM   #5
Earthworkssdu's Avatar
Trade: Utility Contractor
We would usually directional bore the HDPE pipe under the river and tie it back in to the PVC pipe. I have never used the HDPE as an encasement for the PVC. Although I would caution that we have had a problem with long runs of PVC in a conduit coming apart under pressure and reseating themselves when the pressure was off due to no back filling around the joints. Good Luck
Earthworkssdu is offline
Old 07-19-2009, 03:33 PM   #6
Southern Build's Avatar
Trade: Doing it right the first time
Why would you even consider using the HDPE as a casing? Since its fused into one pipe I think the possibility of a leak is tiny compaired to trying to push 20 peices through it following the curviture of the HDPE. We always just join the HDPE to the PVC at each end of the bore. The o.d. should be the same size, although i.d. will be much less on the HDPE.
Southern Build is offline
Old 07-19-2009, 07:24 PM   #7
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
I am confused. Will the 10" waterline be fused or have gasketed bells ?? I would be weary on this because since a pressurized piped will be inside another pipe, there will be no backfill on top of it, preventing a leak. I would talk it over with the engineer and water company. I would much rather see a D.I. crossing or have it encased in concrete.
rino1494 is offline
Old 07-19-2009, 09:13 PM   #8
JDavis21835's Avatar
Trade: Excavation
Around here HDPE crossings are common. But sleeving pvc thru it is not. Around here a flange is fused to the HDPE. Then it is bolted to the rest of the water line. If using HDPE as a sleeve, why not run HDPE pipe thru the sleeve, this way you know it will follow. You also wont have the PVC wanting to on seat itself. If they will not budge, I would recommend grouting the lines once installed, that way there will be no chance of the PVC moving.
JDavis21835 is offline
Old 07-19-2009, 10:09 PM   #9
Kgmz's Avatar
I have a feeling the original poster is confused and doesn't know how to read the plans or has any idea of how things are supposed to be done and why.
Kgmz is offline
Old 08-20-2009, 07:08 PM   #10
js1579's Avatar
I have a feeling youre a douchebag. plans were read correct and project is done. thanks to others who provided positive feedback.
js1579 is offline
Old 08-20-2009, 09:36 PM   #11
Kgmz's Avatar
Maybe I am, but what did you end up doing?
All the other previous poster had never heard of anything like this, and most of them have been in this business for as long as I have or longer, 30+ years.
But I am also tired of seeing these first post questions, contribute something first then ask. I have never asked a question yet.
Kgmz is offline
Old 08-21-2009, 06:25 AM   #12
Vagitarian
rino1494's Avatar
Any pics ??
rino1494 is offline
To all The Newbies Starting Up Their Own Business dirt diggler General Discussion 53 04-27-2011 07:21 PM
indirect water heater v.s. tankless world llc Plumbing 31 02-02-2009 11:28 AM
water water everywhere genecarp General Discussion 7 09-07-2008 08:54 PM
Young Assistant Superintendent needing advice MadDog General Discussion 37 08-07-2007 12:18 AM
Current Project... Need advice. RobertCDF Decks & Fencing 9 11-10-2006 09:04 AM
