Manhole Leaks
Old 06-28-2006, 08:06 PM   #1
dayexco's Avatar
Manhole Leaks
i have a manhole that the invert is 9' into the water table, had a joint failure on the bottom manhole section. have any of you ever used that stuff that comes in a caulking gun tube, you drill a hole through the manhole near the leak, shoot the stuff into the hole, and it seals the leak up? if so, what manufacturer do you prefer, have the best luck with.
dayexco is offline
Old 06-28-2006, 10:25 PM   #2
PipeGuy's Avatar
Trade: underground
Re: Manhole Leaks
http://www.avantigrout.com/#
Look at product AV-202- it's the bomb. We've had reason to use it extensively in high head conditions with great success. Avanti will sell it direct to you by the case. I'll tell you tommorrow the injection technique and hole size we've had the best luck with.
PipeGuy is offline
Aluminum storefront door leaks fabos Windows, Siding and Doors 0 05-12-2006 12:13 PM
manhole sealant dayexco Excavation & Site Work 19 05-05-2006 09:44 PM
Leaks denick Excavation & Site Work 7 04-28-2006 01:03 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Window leaks...Hmmm wonder why! pitterpat Windows, Siding and Doors 9 10-29-2005 05:27 AM
