Lifting Preferences
Old 07-18-2006, 09:50 PM   #1
denick's Avatar
Lifting Preferences
What do you use for lifting? Chain, nylon slings, wire rope slings or something else? What do you use and what do you use it on?
Nick
"Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein
denick is offline
Old 07-18-2006, 10:12 PM   #2
PipeGuy's Avatar
Trade: underground
Re: Lifting Preferences
Sliding hook cables for RCP and large HDPE pipe. Nylon sling chokers for DIP and large PVC pipe. 4-way open-hook cables for trench boxes and large precast structures. 3-way tempered chains for small precast structures.
PipeGuy is offline
Old 07-19-2006, 06:26 AM   #3
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
Grade 80 chains for precast manholes, concrete outlet/inlet structures, catch basins and trench boxes.
We do use wire rope for dragging the trench box. We attach it to the box with a couple clevices and I can reach out and grap the rope with the teeth and drag it.
When lifting manholes, does anyone use spreader bars ?? We have a couple spreader bars, but never used them. We just keep the chains long to prevent breaking the manhole. Has anyone ever had a problem with this ??
rino1494 is offline
Old 07-19-2006, 09:06 AM   #4
PipeGuy's Avatar
Trade: underground
We use a spreader with products made by a certain manufacturer. A chain with a locking pin hangs from each end of the bar which itself is rigged to a cable. It's much easier to 'turn' manholes into position when they're rigged like this. Also. no chance of busting of the top edge of the manhole.
PipeGuy is offline
Old 07-19-2006, 09:02 PM   #5
Vagitarian
rino1494's Avatar
We use swivels. We have 4 or 5 of them. We can swing the manholes 360 degrees.
rino1494 is offline
Old 07-20-2006, 08:55 PM   #6
dirtySiD
dirtdiggencat's Avatar
Trade: M.U. contractor
We use 2 leg sling (chain gr100) and lock pins for manholes, 4 leg for boxes shields and stuff, wire rope choke for heavy pipe, nylon for light stuff.
SiD
________________ Everyone goes home, Every night. ___________________
dirtdiggencat is offline
Old 07-20-2006, 09:03 PM   #7
PipeGuy's Avatar
Trade: underground
I'm not a big fan of chains for lifting. I've seen some pretty ugly stuff happen when chains fail including a guy that damn near lost half the side of his skull to a chain hook that flew clear when the chain failed. IMO, cables and slings serve the purpose of hoisting much better than chains.
PipeGuy is offline
Old 07-27-2006, 08:41 AM   #8
Little's Avatar
Trade: Commercial Construction
Send a message via AIM to Little
Swivels are a must have item, makes life soo simple.
Little is offline
Old 10-16-2006, 06:09 PM   #9
Stephen's Avatar
Trade: renovations
Is there anyway to raise a concrete walkway 4ft. wide by 8ft. long it has sunk about 7in. Mudjacking is quite expensive for this small area, but it is right in front of the first step up, so it makes it a higher reach, which is a pain. Thanks Stephen
Stephen is offline
Old 10-16-2006, 06:30 PM   #10
dayexco's Avatar
hammer it out, compact gravel/stone to subgrade, pour new, you're only talking 32 sq ft
dayexco is offline
Old 10-16-2006, 07:04 PM   #11
tgeb's Avatar
Yep, tear it out and replace it.
Most likely will crack if you try and raise it. Then you have to rip it up anyway.
www.gebcon.com
tgeb is online now
Old 10-16-2006, 09:38 PM   #12
Vagitarian
rino1494's Avatar
Yep, do it right the first time.
rino1494 is offline
Old 10-17-2006, 05:59 AM   #13
jmic's Avatar
If it were me and it went down 7 " and is now stable I'd go over top of it , little process and a new pour.
Joe
jmic is offline
Special tool for lifting needed Versatile General Discussion 21 08-16-2007 12:38 AM
better header, lifting it....... ApgarNJ Framing 11 06-19-2007 11:56 AM
Paint Preferences.... ANewLook Painting & Finish Work 5 10-26-2006 12:41 PM
Insulation preferences maj Construction 1 04-06-2006 03:27 PM
certainteed shingles lifting up on new roof Kim Roofing 2 02-27-2005 07:30 PM
