Laser Level Suggestions
Old 07-01-2006, 08:41 PM   #1
dirt diggler's Avatar
Trade: contractor
any brand??
primary use is checking grade
dirt diggler is offline
Old 07-01-2006, 09:09 PM   #2
denick's Avatar
Re: Laser Level Suggestions
Dirt,
If you are going to use it a lot on sites and you want to be able to toss it in the back of the truck and go. Be careful to get one that is made to take it. Our Laser Alignment LB2 is 18 years old and we're on our second battery pack and it's been cleaned and re-calibrated twice. The LB2 made today is not the same tool. Laser Alignment, Spectra-Precision and Leica are all good brands. The heavy duty models go for 1,500 dollars and more. The less expensive models are not as durable.
Nick
"Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein
denick is offline
Old 07-01-2006, 09:12 PM   #3
Trade: contractor
thanks denick
i figured around 1200 - 1500
Old 07-01-2006, 10:49 PM   #4
dayexco's Avatar
i 2nd the motion on laser alignment products...they're great
dayexco is online now
Old 07-02-2006, 01:16 PM   #5
tgeb's Avatar
I have a spectra-physics (which is now spectra-precision) that is 18 years old and has not needed calibration. Runs on 4 D cell batteries, receiver on 1-9 volt.
I recently purchased 2 David White Lasers.
A cheapo from Lowes a ML-450 for about $200, it worked for only 3 days. I returned it.
The second purchase is a 3175 was about $1,300 and so far seems quite durable and accurate.
You do get what you pay for sometimes.
www.gebcon.com
tgeb is offline
Old 07-02-2006, 07:59 PM   #6
MC Excavating's Avatar
Trade: Excavating, Grading, and Demolition.
I use a Spectra Precision L600. I have had this level for 8 years and has never had any problems. The L600 has a operating diameter of 1,970 ft. The L800 has a operating diameter of 2,600 ft. I like this level because it runs off of 4 D batteries and 2 AA for the reciever. You dont have to remember to charge the battery or run it from a car battery. Just go to the store and buy some or always carry extra. I seem to get pretty good battery life but I also dont use it everyday. If it gets bumped out of level it will stop operating untill it is releveled (nice feature). You can also set it to be out of level so you can do pitch for drainage swales or sewer pipe. This feature comes in handy so you can set it and forget it. You set the fall you want and dont need to keep doing math in your head.
Good Luck.
MC Excavating is offline
Old 07-02-2006, 08:48 PM   #7
Trade: contractor
yeah the Lowe's selection is not gonna work
need a "real" one
Thanks guys
Old 07-03-2006, 07:16 AM   #8
denick's Avatar
Dirt,
Depending on what your typical work is you should also check the degree of accuracy of each unit. They all have an accuracy rating in a given distance most give it at 100' (+/- 1/8" in 100'). some do get up to more than 1/4" in 100" which translates to the possibility of 1/2" difference in a 100' radius of work.
Nick
denick is offline
Old 07-05-2006, 09:33 PM   #9
dirtySiD
dirtdiggencat's Avatar
Trade: M.U. contractor
we use topcon rotators. they were like 1200 a set new and they continue to go the distance.
for pipe its hard to go wrong with trimble.
SiD
________________ Everyone goes home, Every night. ___________________
dirtdiggencat is offline
Laser level for top plates on partition walls? personalt Framing 3 11-12-2006 09:58 AM
I Need Some Laser Level Advice needthingsdone? Tools & Equipment 13 11-11-2006 11:10 PM
level decks on the top floors adman1900 Carpentry 1 11-11-2006 11:20 AM
Laser Level reveivl Tools & Equipment 2 03-02-2006 01:18 PM
laser tools do0f4i Electrical 10 10-24-2005 09:15 PM
