Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Excavation & Site Work
Old 10-30-2009, 06:40 AM   #1
Trade: General Construction
Post Installing water line
I am a local paving/grading contractor and looking to get some information on installing water line. You ride up the road and see those guys trenching for water line down the side of the road. What is a good way I can learn about this without actually having to get out and do it as a laborer. I don't have the time to actually go work on a crew to learn it and run my company too. People are needed to do jobs alot like Dayexco, I believe it was, posted. We have the equipment to do it and it would help keep the guys busy when paving slows down. Any information greatly appreciated!
TERM101 is offline   Reply With Quote
Old 10-30-2009, 09:21 AM   #2
dayexco's Avatar
i know all pipe work is very competitive now....but this particular job with the quantity of pipe involved. "5 miles'....is VERY production driven in order to make any money. you'd quickly regret jumping into a project like this with a green crew. i'm very fortunate that our pipe lead is a REAL hustler. he just does things, no holding his hand, things just get done. a project like this i think would be a tough one to cut your teeth on with the margins we're dealing with.
When the student is ready, the teacher will appear
[b]Do you teach the best what you need to learn the most?[b]
a few pics of our operation and equipment at http://s72.photobucket.com/albums/i182/dayexco/
dayexco is offline   Reply With Quote
Old 10-30-2009, 01:24 PM   #3
Thanks for responding, I can appreciate your reply. Im not trying to say that I am just going to run out and grab a few miles to begin with and expect to get rich at it. I would just like to find out where I can learn a bit about it and maybe progress my way into it. I am just looking for something else to "put under my belt" so to speak incase a good opportunity ever arises. I am basically paying the guys now to do nothing just so they can feed their families until I get the go ahead on a few jobs. I figured meanwhile I could try and brush up on something new.
Old 10-30-2009, 09:01 PM   #4
tgeb's Avatar
Kind of a tough question, Term.
I have worked around these "Pipe Layers" for years.
I have helped out in the trenches, handed the guys bolts and flanges and helped tighten them to make connections.
Watched in amazement while some old Italian guy cut a section of 24" ductile iron pipe with a cutoff saw....and it was perfect.
I've seen guys "hot tap" water mains. Cut in saddles on sewer pipe.
I've seen them fret cause they could not get all the air out of pipe so it could be tested properly.
When it can finally be tested, they have to find out why, and where, they are loosing pressure, dig it up and fix it.
I have worked in some fashion or other, around, and with the pipe crews for almost 30 years, and it is not a trade I would approach sheepishly.
If you intend to take on this type work you will have to be bold, move quickly and efficiently. Most of the work requires specialized tools to some extent.
These old boys make it look easy, that's part of their job, but it takes time, money and mistakes to learn the in's and out's of the pipe work business, same as it would take time, money and mistakes, for one of us who does not handle hot mix asphalt, to venture into your field of expertise.
How you would learn this craft without working it for about a decade or so is beyond me. I don't think it is something you can just "take on" as a fill in for your slack time.
Where are you located?
www.gebcon.com
tgeb is offline   Reply With Quote
Old 10-30-2009, 11:44 PM   #5
Trade: excavating
In my area the guys that do what Day is doing specialize in that and do nothing else. I have done some trench and back fill for plumbers before doing this work but just watched the process of putting pipe together. I never been involved in more than a few hundred feet.
They made it look easy.
IMHO it would be hard to compete with them but I would give it a try if I could overcome one big hurdle. That would be hiring a guy or guy's that did it every day.
I think in your situation that is the best way also, hire a expert to work on your job to make sure your guys do it correct and learn. If I ever do this type of work that's exactly what I will do.
www.macdonoughexcavating.com
jmacd is offline   Reply With Quote
Old 10-31-2009, 10:14 AM   #6
dude abides.
funk5stacks's Avatar
Trade: commercial excavation, sitework, and utilities
and don't forget licensing. sewer tappers, water tappers, fire mains. here in columbus this involves being interviewed by a city board and a written test. and someone on site needs to be competent in trenching and excavating per osha standards.
funk5stacks is offline   Reply With Quote
Old 10-31-2009, 10:25 AM   #7
dayexco's Avatar
it sure wasn't my intent to discourage you....everybody has to jump into the game somewhere. personally, i think i'd find a housing site developer with some site piping, i.e. storm/sanitary/water mains to install....and get your feet wet that way. there's a little of everything involved in that scenario, and it really speeds up your learning curve.
Old 10-31-2009, 04:05 PM   #8
Post
Thanks for the honest reply guys. I know that nothing can teach you as good as actually doing it in the field. Also, I didn't mean to sound ungrateful dayexco, I may have come across as expecting you guys to tell me how its done and viola. I understand that nothing I read will replace experience per se. I was only looking for a little information on how to get my feet wet and maybe advance my way into it. Also, im located in easern NC. Thanks guys for the replies.
Old 11-01-2009, 09:12 AM   #9
Trade: Excavation
Dayexco is right about having to jump in the game somewhere. I think you will find it difficult to do these jobs without having at least one experienced pipe guy on your crew.
Now a days I think diversity is the key due to the lack of work. If I were you, I would start by look for sewer & water laterals. Then move onto subdivision main pipeline work. There is a big difference between installing pipe in a new subdivision & installing on a main road.
Good luck.
Upchuck is offline   Reply With Quote
Old 11-01-2009, 11:24 AM   #10
pce
Trade: the tough jobs
Get some prints, bid on the jobs but don't turn in your bid. Go to the bid letting, see what the jobs are going for, then you will get a feel on the bidding end. You will need to be able to read soil boring reports and understand them and know how they will effect your production. You need the whole crew to be expeirenced to make money. I have did asphalt work and can tell you it is a HUGE difference in underground work. And as noted above the money you will spend on different tools to do the underground will be a big chunck of change. Work is going to cheap for a learning curve to be affordable now, stay with what you know, wait out the slow time untill the prices are a little more forgiving. I don't know everything but 30+ years of doing underground work I have learned a few things, that the pros make it look easy. Dan
pce is offline   Reply With Quote
Old 11-02-2009, 09:01 PM   #11
Trade: underground
God bless you guys.....you're bigger men than I am.
That's the way that the world goes 'round, you're up one day and the next you're down.
It's a half an inch of water and you think you're gonna drown, that's the way that the world goes 'round.
PipeGuy is offline   Reply With Quote
Old 11-06-2009, 05:04 PM   #12
sam74
Trade: Civil and Site engineer
I had the opportunity near the start of my career to do about a year of surveying followed by a year of water line installation inspection. I knew nothing about it going in and was told nothing about it other than make sure the pipe had proper coverage and watch the backfill material. I learned bunches about it just by watching.
I met some good people and some idiots. The sons of the owner of one of the contracting companies worked on the field crews. They more or lessed half assed it. But there was a young dude who worked his ass off all the time and he was easily going from the trench to the loader because that operator was impressed and occasionaly to the track hoe because the crew leader was impressed. The sons of the owner hated him. So I'd say your crew will make a big difference and you'd better have atleast one well seasoned dude. Most of the trench guys seemed to come and go but not all.
I didn't lay a stick personally but probably should have atleast tried it to say I'd done it. I should have also learned to weld while they were doing jack and bores but turned down the offer from the crew chief. I learned what they were doing though and could anticipate enough to stay out of their way. If it was one of the good crews I'd often go grab some hot lunch for them. One guy you had to watch like a hawk and another you could go take a 2 hour nap and not worry.
Hot taps, failed tests, track drill rigs, hoe rams, hole hogs, taking a 6" mj valve off of a pressurized line (they must of been hungover that day), fire in the hole, broke gas, water, and fiberoptic lines, and many other knowledge gaining experiences.
That's another thing you'd need someone with exploxives permitting unles your in a city.
Steve Manning is offline   Reply With Quote
Old 11-06-2009, 07:28 PM   #13
tgeb's Avatar
Your's was the best post before you edited it, funny as hell, you should have left it be.
www.gebcon.com
Old Yesterday, 09:59 PM   #14
Trade: underground construction
i do this for a living. 100-200 mile jobs. what do you want to know.
whatley posse
rshackfleford
rshackleford is offline   Reply With Quote
Tags
term
Could water heater be overheating and overflowing? bob_cntrctr Plumbing 18 03-17-2009 07:39 PM
Water Line Saddle CC NPT IHI55j Excavation & Site Work 3 03-15-2009 05:09 PM
Sump Pump - Burying the Line Deeper - How Deep? AboveAndBeyond Remodeling 4 02-11-2009 12:22 PM
Hot Water Heater making loud sound and vibrating the entire wall BKFranks Plumbing 9 10-27-2008 09:58 PM
installing granite submerged in water MattCoops Ceramic & Stone Tile 14 04-06-2008 08:44 PM
