Inspections
Old 04-16-2006, 09:30 PM   #1
jmic's Avatar
Inspections
Just curious. Do all the towns you work in require footing drain inspections before you backfill ?
Joe
jmic is offline
Old 04-16-2006, 09:32 PM   #2
denick's Avatar
Re: Inspections
Yes.
Nick
Not in NY though.
denick is offline
Old 04-16-2006, 09:37 PM   #3
jmic's Avatar
Re: Inspections
Not in Greenwich either which I thought was strange when I first started to do work there, but it comes in handy when you have to backfill your way around to get to the back yard.
Joe
jmic is offline
Old 04-16-2006, 09:44 PM   #4
dayexco's Avatar
Re: Inspections
after a rash of shoddy, no longer in business contractors during the mid 80's...EVERYTHING here gets inspected. the site has to have a hole dug, (can be with post hole digger) the depth of basement excavation and stand for 48 hrs. to make sure there's not a surface water problem, the excavation must be inspected before footings are poured, drain tile inspected before backfill, water/sewer lines tested. overkill maybe, but we get paid for it, and customer, city knows what they have to contend with.
on our development work, the developer is required to have a full time inspector at his expense to watch us put in water/sewer mains and the laterals. again, if you're the type to do things the right way, they're no bother at all. our sewer lines are air tested at 5lbs. for one minute per pipe inch., water lines at 120 psi for 2 hrs., manholes must be filled to rim with water and stand 2 hrs. with zero loss, or you can vacuum test them.
dayexco is online now
Old 04-16-2006, 09:50 PM   #5
jmic's Avatar
Re: Inspections
Nick ,
I did a job in N.Y. a few yrs. ago and they didn't even care that I was licensed to do septics. Is that all over in N.Y.?
Joe
jmic is offline
Old 04-16-2006, 10:03 PM   #6
denick's Avatar
Re: Inspections
Joe,
It seems in the upper counties. There is no septic license and NO regulation on repair of systems where we have worked?
In NY All new systems have to be inspected by an engineer. If a system needs to be designed by an engineer and inspected by an engineer why do you need licensing?
Nick
denick is offline
Old 04-16-2006, 10:05 PM   #7
jmic's Avatar
Re: Inspections
To help fill the State coffers?
Joe
jmic is offline
Old 04-16-2006, 10:52 PM   #8
theman's Avatar
Re: Inspections
In Dutchess County N.Y The County Health Dept issures all permits and does all inspections then tells the Bld Insp to issure a C.O.
theman is offline
Old 04-17-2006, 06:24 AM   #9
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
Re: Inspections
In my area, they don't check the drains, but they do check to make sure that there is fabric over the stone before I backfill.
rino1494 is offline
Old 04-18-2006, 06:14 AM   #10
chrisherk's Avatar
Trade: electrician and excavation
Re: Inspections
One town in NH had no inpections for the whole house, but the next town over, so far wants to inspect the footing drain before backfil. I think he wants to check my rough wiring and plumbing before i cover it
Town of Ossipee that is.
chrisherk is offline
Is failing inspections bad for business..... Bsecdone General Discussion 18 05-10-2007 10:52 PM
Inspections CE1 Electrical 13 01-06-2007 11:13 AM
Anyone else bothered by inspections? nadonailer Construction 17 06-05-2006 11:45 PM
How to handle inspections Mike Finley General Discussion 6 06-17-2004 10:46 AM
Insepctions Bjd General Discussion 14 04-24-2004 11:00 AM
