I Have Never Seen A Screw Up This Bad
Old 09-10-2009, 08:52 AM   #161
oldfrt's Avatar
Re: I Have Never Seen A Screw Up This Bad
Originally Posted by mics_54 View Post
I think the stains are splash from runoff like he said...the wing to the left has the same stains and from the ground level and vegitation it wasn't ever back filled that high there either.
If you look at that picture,you got to notice also that the backfill in that area has been disturbed.Maybe at the same time the lower wall was dug out.
Notice the lack of green and the irregular mounds.Maybe part of the boyfriends work?
Sherlock Holmes hat off!
Gotta get to work!
oldfrt is offline
Old 09-17-2009, 08:41 AM   #162
jmacd's Avatar
Trade: excavating
All done patio and lawn. Bought a new straw mulcher this year, have had to rent in the past. I have put in a lot of lawns this year.
jmacd is offline
Old 09-17-2009, 12:33 PM   #163
jomama's Avatar
Trade: Concrete & masonry
Looks good.
BUT, where's the close-up of the stamped patio!?
jomama is offline
Old 09-17-2009, 01:37 PM   #164
jmacd's Avatar
Trade: excavating
I meant to get one, came out real nice. Maybe next time I am over there I will take one. I also wanted to get a photo of new chopper lay down the mulch, forgot that also. We put down 25 bails in a hour. I use a power rake made by Bobcat, bought it new when I started and have used it on every project that has lawn involved.
This is what we use except my skid steer is a New Holland:
jmacd is offline
Old 09-17-2009, 08:31 PM   #165
Stud
Upchuck's Avatar
Trade: Excavation
Gotta love bobcat attachments. I remember raking lawns w/o any screened loam or equipment. As a kid the guys would rake everything into piles. I would shovel it into a wheelbarrow and dump in woods. Only rented rockhound few times before buying one. We've had it 15 yrs. & I enjoy raking lawns much more now.
Upchuck is offline
Old 11-17-2009, 01:34 PM   #166
kingston's Avatar
Trade: Architectural/Historic Restoration and Preservatio
I do not see any evidence of this foundation being "frost protected"...
Q.Does the residential code require footings to frost for all buildings?
A. No. Section R403.3 entitled “Frost protected shallow foundations” provides that for buildings where the monthly mean temperature of the building is maintained at a minimum of 64ºF (18ºC), footings are not required to extend below the frost line when protected from frost by insulation in accordance with Figure R403.3(1) and Table R403.3.
EXCEPTIONS:
1. No foundation not so protected may be attached to frost-protected shallow foundations.
2. Unheated garages, porches, utility rooms and carports shall not be permitted to be attached to dwelling units with a frost-protected shallow foundation.
Materials used below grade for the purpose of insulating footings against frost shall be labeled as complying with ASTM C 578.
[/quote]
Spires & Co.
Architectural and Historic Restoration, Preservation, Design, and Consulting
http://www.spiresco.com/
kingston is offline
Old 11-17-2009, 09:45 PM   #167
Al Smith
A W Smith's Avatar
So how did she get a C of O with a slider that opens to a 6 foot drop? And no gutters no C of O here in jersey.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 01-30-2010, 04:45 PM   #168
dstover's Avatar
Trade: general contractor
I think the term you are looking for is FPSF (frost protected shallow footer)
dstover is offline
Old 01-30-2010, 06:25 PM   #169
BCConstruction's Avatar
Trade: Construction
Good question. I see them all the time around here. Couple of deck jobs ago i done they had the same thing but it was 4 sets of double slideing doors with a 15ft drop out of each one.
Originally Posted by else bronx View Post
But you cant do Cement work. your a plumber. thats it. by trade. nickels and dimes.
BCConstruction is offline
Old 02-03-2010, 07:10 AM   #170
72chevy4x4's Avatar
I've seen sliders around here too but w/a piece of 2x6 decking screwed to the outside as 'railing'...not sure if the doors open though.
72chevy4x4 is offline
Old 02-17-2010, 10:42 AM   #171
George-NJ's Avatar
Trade: New Home Builder, R/E (rentals), Home Improvement
I couldn't make out the measurement from the pic from the bottom of the footer to the bottom of the window. It looked pretty close if not good (although dirt should've been all the way up). A little sloppy with not putting the asphalt coating up to where it should be, a kid probibly did it. You can see the seem in the wall from the pour panels about mid window height, so you can see where they stepped the footing down at about the inner edge of the windows to compansate for the exposed door in the footing. It looks like it was part of a multi home subdivision, things kind of get a little sloppy in alot of those cases, little things seem to get lost in the chain of command.
The home wasn't final graded to where it should've been. Around here I would've had to bonded for the final grading to get a waiver from the Soil Conservation Dept (a/k/a soil nazis) to get a c/o for this home, and only because of winter. I would've had to still put a mulch & a tack cover on in order to get the bond anyway. About $1,500 for an acre of disturbed ground for that bond. Perhaps the builder was coming back anyway to finish, or was supposed to?
Should've had a temp railing over the upper patio door to get a c/o.
Having been a concrete truck driver in the past, I've seen plenty of poured open trench 4' footings with a couple of feet of block or pour panels set up on top. I've seen them on single homes & large attached condo projects. I did my first new home that way as well, the local inspector had no problem with it. I know that other trade guys aren't on the job at this point to see the footings go in, but there are alot of poured trench footings around, so check for it if there is a question about footing depth.
George-NJ is offline
Old 08-02-2010, 04:53 PM   #172
Jaf's Avatar
Trade: Builder
Holy shmooks, what a good read this was. Like a regular detective novel. Best part was the last poster, who noticed what everyone else (including I) missed. The patio door.
Looks like framerman was right all along, but missed the additional clue, like everyone else.
Sorry to bump this back into circulation, but I couldn't resist. Jmac still around for an update?
Edit: Hmmm, unless they where planning on adding a deck all along... Maybe, I'll go back to sleep.
Jaf is offline
Old 08-07-2010, 09:18 AM   #173
jmacd's Avatar
Trade: excavating
Jaf, I am still around and here is your update. All is good, customer happy, recommended me to a few other customers that turned into work so there is a lesson in there some were.
jmacd is offline
Old 12-18-2010, 12:22 PM   #174
Life Apprentice
mehtwo's Avatar
Trade: Plumbing & Carpentry
Sorry to resurrect on old thread(I just signed up with CT), but why not have retaining walls that are perpendicular with the back wall so the dirt isn't right below the windows?
mehtwo is offline
Old 12-18-2010, 12:40 PM   #175
Framer53's Avatar
Trade: Framing
that is what the customer wanted.
In fact she now has a deck built over the window to the slider.
She is a customer of mine as well as John's.
Framer53 is offline
Old 12-18-2010, 04:40 PM   #176
Cuda's Avatar
Trade: Plumbing and Sewer Contractor
This thread was sure long but glad I read it.
Cuda is offline
Old 12-18-2010, 05:26 PM   #177
jmacd's Avatar
Trade: excavating
Cuda, glad you enjoyed it!
That thread was fun to be involved in and think most would agree was a learning experience for all.
jmacd is offline
Darn!! Did I just screw myself? Presure Washing job Titodbuilder Business 5 08-21-2009 08:02 AM
screw indents Vrooman Drywall 34 04-29-2009 01:49 AM
collated screw guns for backer platinumLLC Flooring 3 12-01-2008 07:11 PM
Screw length for fastening 2 x Ipe? Chris G Decks & Fencing 9 09-18-2008 07:50 PM
Auto feed screw guns vs. pneumatic screw nailers sk8park Tools & Equipment 9 04-07-2008 11:41 PM
