Hydro Excavation
Old 10-09-2017, 02:45 PM   #1
Cobrajet31266's Avatar
Trade: Excavation
Hydro Excavation
Can some one please educate me on the difference between a hydro vac truck and a sewer/rodder truck. Is it just the rodder reel on the front or are there other differences. Can you use a sewer vac truck for hydro excavation? And if so what kind of nozzle are you using on the jet hose? Any help is appreciated.
Cobrajet31266 is offline
Old 01-10-2018, 11:23 PM   #2
Mhaskins's Avatar
Trade: Site work and Underground Utilities
Rewards Points: 6
Re: Hydro Excavation
The largest difference is what the truck is set up to do. Some of the trucks and do either. A Badger truck will only suck. It does have water for potholing but Iíve never seen a Badger Truck with a sewer jet reel. Some of the sewer jetters have a vac and older models are just stand along jetters.
Mhaskins is offline
Old 01-11-2018, 04:44 PM   #3
Trade: Excavation
So can a sewer truck be used for pot holing?
Old 01-11-2018, 07:08 PM   #4
dayexco's Avatar
Rewards Points: 586
well, yeah you could.....would i use a cat 307 on a 20' deep excavation? sure, it can be done if i want to dig myself down a couple of times, but not it's real intended purpose
dayexco is offline
Old 01-11-2018, 08:01 PM   #5
Trade: Excavation
Well I guess what I'm confused about is what makes a truck set up specifically for hydro excavation any better then a sewer jetter truck looks like you would have the best of both worlds besides it seems like you can pick up a Vactor truck allot cheaper then any actual hydro excavation truck?
Old 01-11-2018, 11:17 PM   #6
Mhaskins's Avatar
Rewards Points: 6
A vactor will work and can also jet. Some also depend on what type of vacuum pump is on the truck as well. Many of the vactors have a big fan. Most of the better performance trucks designed for potholing will use a positive displacement pump. Most will work either way. Some work better doing certain things. Just depends on your main use
Mhaskins is offline
Old 01-11-2018, 11:41 PM   #7
Trade: Excavation
I see and what is the function of the fan on the vactor?
Old 01-11-2018, 11:47 PM   #8
Trade: Excavation
I'm looking for something to mainly do pot holing and excavation work but having the rodder available would be handy at times
Old 01-12-2018, 09:33 AM   #9
Mhaskins's Avatar
Rewards Points: 6
The fan on the vactor is how they get their vacuum instead of a pd pump. The fans have to have air movement in order to work. The pd pumps can be completely submerged and still work although it performs better with air movement.
As far as the rodder they can be useful if your in that line of work
Mhaskins is offline
Hydro One (Ontario) Temporary Service Hookup Fee Dunvegan Electrical 2 05-10-2017 02:51 PM
Excavation variables: HOW MUCH TIME? ericscher Excavation & Site Work 6 03-18-2016 11:26 PM
Hydro Jetting Before and after videos Cuda Plumbing 3 09-29-2012 12:51 PM
Excavation for Budget Granrey Excavation & Site Work 8 01-14-2009 08:24 PM
