Trade: excavating
How Much Shrink Will You Get With Compaction
I'm estimating a little dirt project and I need to know how much shrinkage I can expect with 98% compaction. For easy math, let's say I have 10cy on a truck what will I have when it's compacted?
"The beatings will continue until morale improves." |
Trade: Excavation Contractor
Re: How Much Shrink Will You Get With Compaction
I always figure at least 20% with soil. If I have a bad feeling about it, I bump it up......it all depends since soils vary so much. 10 yards would compact to 8yds or less depending. That is how I do it, but that may not be correct. I'd love to hear what other guys use for a compaction factor.
take a sample of the soil to a soils engineering firm...have them determine your maximum dry density...go from there. anything you hear form us will be bogus, we have no clue as to what soil types, moisture contents you're dealing with....and, i'm not a soils engineer!
fwiw.....when i'm dealing with a cohesive soil...i estimate a min. of a 33-35% shrink....granulars, min. of 25%
someday, i'll be as patient as Nick. |
It really depends on the material you have.
Can you get more specific cdub? For the most part I think C's method would work well, as would Dayexco's guidelines. Last edited by tgeb; 12-11-2008 at 08:38 PM. |
Trade: excavating
I would call the material a silty clay. The material will be excavated from bank but the pay item is compacted fill. I'm trying to calculate production knowing the loose volume of my trucks but not the compacted volume. I've searched a little and found information to support both of you. I realize its a soil specific factor. I was just curious what rules of thumb you guys use. I would normally call a 15 yard truck 10 compacted, but I can't remember where I came up with that.
Vagitarian
Obviously it depends on the soil and the moisture content, but I usually figure 25%.
As day and rino said 25% for granular soils. 33% to 40% in clay soils.
Nick "Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein |
Vagitarian
What are you building and what is your method of compaction ?? 98% seems like a pretty high standard. We recently completed a building pad for a 53,000 sq. ft. building and it called for 95% compaction. 12" lifts, we were getting about 102 with our Cat CS553 roller.
How much material are we talking about here. I wouldn't be too picky about percentage unless you are talking alot of material. As long as you are in the ballpark, you will be ok.
Midnight
Trade: Excavating, Grading, Demolition, Underground Utilities
25 percent will get you really close in any soil. When I bid projects 25,000CY or less that is what I use. If I am going to move more than 25,000CY then I will take a sample to the nerds.
"It is what it is" |
Trade: excavating
It's an auxillary spillway repair on a lake. There is about 20,000 of compacted fill. The farthest haul is about 1000 feet and averages about 300-400 ft. I was planning on getting some sort of vibratory roller for compaction. I've got along real well with them compacting sewer trench backfill (100+%) if the guys will slow down and let it do its work.
i'm going to bid every "clay" job i can get my hands on...and sub it to you!!!
Midnight
I guess I should have clarified a little more. Day hit the nail on the head with knowing the material you are moving. 25% would be a very crude example and would work for sand to sandy lean clay. If you are in a real plastic clay 35% - 40% wouldn't be out of the question. I wouldn't bid a plastic clay site with a 25% shrink factor, lucky for me this area is usually sand - sandy lean clay.
#13 | |
Trade: excavating
Re: How Much Shrink Will You Get With CompactionQuote:
I appreciate the advice guys. Thanks.
#14 | |
Trade: excavating
cdub,
If you need 200 cy to fill a hole of measured size. you need to dig 200 cy of dirt out of a bank. When you excavate it and dump it in the truck it swells to 270 cy at the 35% swell factor. You need to transport 270 cy. If you dump that 270 cy on the ground and compact it 100% it has a shrinkage factor of .74 All this depends on the material your digging is at a 100% compacted density. for that particular soil. if it was disturbed already and loosened it might already be in a swelled state. If the material that has been packed like iron for the length of a project and you start digging it it may swell at a factor X's 2.
#16 | |
Vagitarian
Obvisously we don't work 100% for a full day. On avg. I figure that we work 50 min out of every hr. So, when figuring jobs, I figure how much material can be moved per hr and multiply that my .83 to get actual.
Midnight
I will post up a chart and some literature on the subject when I get around to scanning it. Probably tonight sometime.
#18 |
Trade: excavating
For my cycle times I figured the number per hour at maximum production then reduced that number by estimated dowmtime. I think that its a round about way to the same end.
| Stranger than fiction (do houses shrink?) | HANDM | Remodeling | 17 | 01-19-2009 02:40 PM |
| Compaction Factor for "Reference" Road Base | Palisade Mike | Concrete & Paving | 2 | 05-22-2008 08:34 PM |
| Soil compaction | joasis | Commercial Construction | 1 | 05-06-2008 09:30 AM |
| Excavator Mounted Compaction: Static roller vs vibratory roller or plate | artherd | Excavation & Site Work | 5 | 07-02-2007 10:36 PM |
| Compaction Quiz | denick | Excavation & Site Work | 8 | 04-17-2006 11:33 PM |
