Horizontal Boring Ideas Needed
Old 11-01-2009, 08:15 AM   #1
ConstSvcs's Avatar
Trade: New home and remodeling
Hi all,
I need your thoughts on this. On a current job of ours the customer has decided to switch from overhead to underground electrical service. The path to the closest pole will require us to cross the driveway apron of the house next door. The driveway we need to cross is stamped concrete ! So.......as I have seen cable contractors do in the past........I was thinking of pushing a sleeve if thin wall 4" steel across the apron. The ground is course to fine sand and should be fine at the depth of my 3' trench.
Any thoughts? I want to avoid dealing with cutting, patching and matching the stamped concrete.
Tom T
ConstSvcs is offline
Old 11-01-2009, 08:58 AM   #2
TimelessQuality's Avatar
Trade: GC/Remodeling
Re: Horizontal Boring Ideas Needed
How wide is the drive?
Since when do you guys pick the shortest distance?
-Steve
"The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein
TimelessQuality is offline
Old 11-01-2009, 11:41 AM   #3
ConstSvcs's Avatar
driveway is 12' wide
Old 11-01-2009, 11:54 AM   #4
Williams Ex Co's Avatar
Trade: Excavation, land clearing, sewer/water
BorZit tool.... 12' should be a breeze. www.borzit.com
Williams Ex Co is offline
Old 11-01-2009, 11:58 AM   #5
tgeb's Avatar
I would try either one of those pneumatic "bullets" or a gas powered auger with bit attachments.
I know a plumber that used to auger a 2" hole under drives and walks with a bit welded to black iron pipe, he would add pipe sections as he worked the bit into the boring.
It worked pretty well.
The problem with just pushing a pipe through, is the pipe will then be filled with compacted soil, unless you cap the pipe and then you will have difficulty getting it through.
With the sandy soil you say you have, I would consider a jetter attachment hooked to a pressure washer, and follow it into the boring with 3 or 4" pvc pipe. But I have a washer and jetter attachment.
I am sure there are dozens of other ways to skin this cat, just pick one.
www.gebcon.com
tgeb is offline
Old 11-01-2009, 03:48 PM   #6
tgeb's Avatar
That borzit tool looks pretty neat, similar to what my plumber friend used with water injection, and it looks like it would handle hard soils and rocky stuff better than the tulip bulb auger he had welded up.
www.gebcon.com
tgeb is offline
Old 11-01-2009, 05:33 PM   #7
custom patios's Avatar
Trade: masonry, hardscape
[quote=tgeb;798739]I would try either one of those pneumatic "bullets" or a gas powered auger with bit attachments.
The bullet is a great tool. I used it to span about 20 feet of entrance at a shopping center to run irrigation. had to make sure my starter trench was nice and level first. theres no guarantee though cuase if you hit a rock, it deflects and starts a new path. back it up and try again. being that you said its sandy it should be no prob.
custom patios is offline
Old 11-01-2009, 08:46 PM   #8
Master of the Underground
Noodle's Avatar
Trade: Electrical
I would be carefull in sand with a "mole" (bullet) because we have lost one because it dive bombed after about halfway across a 15' to 20' span. Of course that is just my experience with them. I would also like to point out that I have had very good experience's with them too.
"Ability is what you're capable of doing. Motivation determines what you can do. Attitude determines how well you can do it." Lou Holtz
Noodle is offline
Old 12-21-2009, 10:01 PM   #9
pcdrifter's Avatar
Trade: general contracting,excavating,tree removal
I bought the Borzit Tool to install 7 different water lines under an 18' private road. This tool worked great even in somewhat rocky soil, I just upped the water pressure a little.
pcdrifter is offline
Old 12-21-2009, 10:08 PM   #10
backhoe1's Avatar
Trade: excavating contractor
we usedto use the borzit tool alot for sprinkler lines. went through alot of drills that way! you haveto be real careful to keep it up out of the water.
backhoe1 is offline
Old 12-22-2009, 10:51 AM   #11
MarcD's Avatar
Trade: Making Everyone Happy
Dont cut the driveway, just punch and tug a line under it. Call around that is pretty easy as long as your ground is not frozen solid right now. If so reschedule. Also if you are switching to underground will your utility do that check with them also. Here we just have to have the box ready to go and they hook up service.
MarcD is offline
Old 12-22-2009, 07:04 PM   #12
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
Where are you located ??
rino1494 is online now
Old 12-22-2009, 08:19 PM   #13
ConstSvcs's Avatar
I did purchase the "Borz-it" tool will give you an update when I get to use it.
Needed illeagal aliens floorinstall General Discussion 9 04-02-2009 05:48 PM
Tampa, FL. Concrete Forklift Ramp Needed phattractor Help Wanted or Looking For Work 0 02-10-2009 02:26 PM
Roofers needed in Sea-Tac Deadhead Derek Help Wanted or Looking For Work 0 02-06-2009 11:32 AM
Work needed. Painter/Paperhanger miagregg Help Wanted or Looking For Work 0 02-04-2009 01:01 PM
Need some ideas... KMac Finish Carpentry 50 01-31-2009 03:06 PM
