Holding Leaching Field Pipe While Installing Rock Over It
Old 08-30-2017, 06:04 AM   #1
farmboy55's Avatar
Trade: Excavating
Here in my area we are required to use 4x10 ADS black perforated pipe in our rock trench for septic systems. 6" under it & 2" on top total of 12" rock
I've seen the box built that you drag thru the trench and it lays the pipe and rock
Would like to see everyone's tricks/devices
farmboy55 is offline
Old 08-30-2017, 08:32 AM   #2
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,140
Re: Holding Leaching Field Pipe While Installing Rock Over It
For the record, 6 +2 is 8. Other than being a troll I got nothing.
Sent from my SM-N910T using Tapatalk
sparehair is offline
Old 08-30-2017, 08:58 AM   #3
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,622
I use little sections of 6" pvc pipe. Cheap, easy to roll and if the operator accidentally buries one its no big deal.
jhark123 is offline
Old 08-30-2017, 12:10 PM   #4
dayexco's Avatar
Rewards Points: 1,896
Why not have somebody hold it while you're putting on your cover aggregate?
dayexco is offline
Old 08-30-2017, 01:14 PM   #5
Frank Castle's Avatar
Rewards Points: 1,106
Originally Posted by sparehair View Post
For the record, 6 +2 is 8 + 4(pipe & rock beside it) = 12. Other than being a troll I got nothing.
I assume you knew that.
Troll on.
Adapt, Improvise, Overcome.
Frank Castle is online now
The Following User Says Thank You to Frank Castle For This Useful Post:
sparehair (08-30-2017)
Old 08-30-2017, 01:36 PM   #6
sparehair's Avatar
Op said 12" rock not 12" total. I dont care what he meant I only care about arguing abiut nothing until all relevant information is lost and the op gives up on the forum in utter frustration and despair as his fundamental understanding of basic arithmetic is cremated in an altar of unabashed egotism.
The Following User Says Thank You to sparehair For This Useful Post:
Rio (08-30-2017)
Old 08-30-2017, 02:03 PM   #7
If it weren't for X-mas coming and the 2017 Drive: Marine Toys For Tots, plus I tweeked my shoulder this morning (moving my own rock) and can't do anymore work today. So, I'll play.
How are you gonna get the 2" of rock to stay on top of the pipe without 4" rock next to pipe?
2 Pipes?
1 for leach field
1 for Mary Jane
sparehair (08-31-2017)
Old 08-30-2017, 05:04 PM   #8
farmboy55's Avatar
Trade: Excavating
Tuff bunch here for sure 😳😳
Old 08-30-2017, 07:57 PM   #9
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,408
Around here they use stone slingers.
http://stoneslinger.com/
Home Designer Series Software
B.Johnson is offline
The Following 2 Users Say Thank You to B.Johnson For This Useful Post:
Rio (08-30-2017), RLH_CT (09-01-2017)
Old 08-30-2017, 08:15 PM   #10
Just like the job site.
Old 09-04-2017, 04:28 PM   #11
Vagitarian
rino1494's Avatar
Rewards Points: 2,388
Lay down your 6" of stone using excavator and laborer to rake off and maintain grade with a laser level. Install pipe and use excavator to place additional stone ontop of pipe.
rino1494 is offline
The Following User Says Thank You to rino1494 For This Useful Post:
dayexco (09-06-2017)
Old 09-05-2017, 10:54 AM   #12
Fishindude's Avatar
Trade: Industrial
Rewards Points: 384
We have made up some steel rod stakes with adjustable support brackets to suspend the pipe in place prior to installing stone. Get the pipe all shot in nice at proper grade, then trickle the stone in place gently. Pull the stakes and brackets after stone is in place enough to support the pipe and re-use them on next job, then fully cover the pipe with stone.
Have also done same thing making up wood stakes with brackets in the field and just abandon them in place in the trench with pipe.
Fishindude is offline
The Following 2 Users Say Thank You to Fishindude For This Useful Post:
farmboy55 (09-06-2017), NYgutterguy (09-11-2017)
Old 09-06-2017, 07:30 PM   #13
Moxley-Kidwell's Avatar
Trade: Excavation & Asphalt Paving
Rewards Points: 286
THIS! Don't over complicate it. Get the bottom stone on grade, lay the pipe, put half a bucket on each stick to keep it in place and then backfill the rest. No reason to waste time or money on gadgets to keep it in place.
Moxley-Kidwell is offline
Old 09-07-2017, 08:45 PM   #14
tgeb's Avatar
Rewards Points: 908
I've installed a lot of septic systems all by myself. I get the base stone on grade, set the pipe in place, (I prefer to use pvc pipe, it lays strait better).
When I cover the pipe I will approach the trench with the loader at a slight angle, enough that when the stone is dumped it will cover both sides and the top of the pipe, the pipe stays centered in the trench no problem.
www.gebcon.com
tgeb is online now
The Following 2 Users Say Thank You to tgeb For This Useful Post:
dayexco (09-08-2017), jhark123 (09-11-2017)
Old 09-11-2017, 01:15 AM   #15
jhark123's Avatar
I should add, I am using rigid pvc, not sure why you would use ads. If I was using flexible pipe, I would definitely put the 6" of rock down first.
jhark123 is offline
Installing grab bars in fiberglass tub shelf guy Kitchens & Baths 26 09-22-2015 01:42 AM
How do I run a new vent pipe and tie in 2 toilets NC2X4 Plumbing 21 07-24-2013 10:31 PM
custom bookcases vs. radiator pipe. Rich D. Construction 2 12-13-2011 09:21 AM
