Trade: excavator
Hitachi Excavator EX200-5
why on Hitachi excavator EX200-5,one side chain tread run faster so it will run to one side?Thank you very much.
Re: Hitachi Excavator EX200-5
Well let's start with the simple things.
Have you cleaned up the floor board and inspected around the mountings to make sure there is no mud, stones or other debris that would limit the travel of the controls? A little lubrication might be in order. Have you followed the linkage from point to point to make sure it it not bent or contacting part of the machine or other component? Next would be to verify the adjustment of the linkages. Then check the hydraulic hoses for the entire circuit, for kinks, or crushed or kinked hoses and tubes, areas of deterioration. Visible Leaks? Make sure and change the hydraulic filter. Next in line would be a pressure test on the drive motors. You'll need the manual and some specialized tools for that. I am sure I may have left out a few things, but this will get you started. |
Trade: Excavation Contractor
TGEB pretty much nailed it. If both tracks are working and just not balanced, then you're more than likely looking at minimal issues as described.
I once ran an old Insley that had a major seal out on the reverse side of one track and would blow oil everywhere if you tried to use it. I got very good at planning my routes so as to not have to turn that track in reverse........it was quite the deal. Glad it wasn't my machine cuz I would have gone broke trying to maintain it correctly. They just ran it that way and didn't seem to think it was worth fixing. |
#4 | |
Trade: Remodel and new construction Austin, TX
Re: Hitachi Excavator EX200-5Quote:
Damn tgeb, You would be a great helo crew chief and helo mechanic.
Robin303 Army Air Slideshow |
Thanks Robin, I have fixed plenty of things but I don't think I am qualified to work on something that when it breaks......it falls out of the sky.
I'll leave that to you pros. |
Registered dumb ass
Trade: Excavator/Underground/Septic Installer
also if you can track down the hoses that supply the drives you can try swapping them left to right, if your problem changes sides then it's not the drive as was mentioned. if it stays with the original side then your kinda stuck with a rebuild of the drive...
that is if you have checked everything else and changed the filter...
yellow locates mean abandon right? |
| Hitachi NR90AF Framing Nailer | 2ndGen | Tools & Equipment | 14 | 01-15-2010 08:33 PM |
| Brand New Hitachi Stick Nailer& Roofing nailer | done4fun | Contractor Swap | 2 | 06-23-2009 01:14 PM |
| Hitachi nr83a2 or nr90ae | jansondt | Tools & Equipment | 18 | 05-20-2009 01:13 AM |
| can you use bostitch roofing nails in a hitachi? | mikeybobo | Roofing | 2 | 12-31-2008 08:40 AM |
| do bostitch roofing nails fit a hitachi? | mikeybobo | Tools & Equipment | 0 | 12-30-2008 09:46 PM |
