Help Removing Bucket Teeth
Old 01-04-2007, 02:58 AM   #1
690E's Avatar
Trade: excavation
Bought a 690E excavator at auction and have some teeth retainers that are new to me. Its an Esco 42" Heavy duty bucket and the teeth are at about 50%, but will need to add some rock teeth soon. The teeth appear to be quarter turn twist lock [lets say] with a single straight retainer along one edge.
Trying to drive this squarish pin out either way is like pounding on a railroad track - no go with any size sledge.
No Esco people around here and we are way out in the woods. Anyone know the secret to this retainer before I get the torch hot?
690E is offline
Old 01-05-2007, 09:05 AM   #2
jmic's Avatar
Re: Help Removing Bucket Teeth
690,
Have the same set up on our buckets. Like the system but they can be a pain to get off sometimes, but I've never had a tooth come off with the twist on. You have to clean them real good and it helps to have pressure on the tooth ( towards shank ) and then use a big hammer, have someone else hold the punch ( don't be skweemish if you see blood ) If you have to try knocking it out both ways. It'll come out! You've probably already gotten it out, but good luck.
Joe
jmic is offline
Old 01-05-2007, 04:31 PM   #3
denick's Avatar
Joe,
If your not squeemish when you see blood would you mind coming up soon and hold the drift for me I need to change a set of teeth soon?
Nick
"Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein
denick is offline
Old 01-05-2007, 04:48 PM   #4
jmic's Avatar
Nick there you go twisting things again. More than happy to go and help the elderly but I'm gonna be the one swinging the hammer, besides you're all up on your first aid courses right?
Joe
jmic is offline
Old 01-06-2007, 03:10 AM   #5
690E's Avatar
Trade: excavation
Thanks for the tips .... I will try pressure washing and then put some down pressure on the teeth before beating. To avoid the blood, I have brazed the drift-driver to an extension handle.
are the pins reusable, and do you definitely HAVE to drive them out in one direction only?
Thanks for the help
690E is offline
Old 01-06-2007, 10:31 AM   #6
jmic's Avatar
690,
I looked at the pins that I use and they look like they can go either way.
I always use new pins when replacing new teeth, but save some of the old ones in case you're ever in a bind. The key is getting some pressure inward on those teeth to drive the pin out. Good Luck!
Joe
jmic is offline
Out of the Bucket? farrellpainting Painting & Finish Work 33 03-27-2007 08:27 PM
Removing asbestos floor tile: Space suits needed? Ted W General Discussion 19 01-29-2007 02:38 PM
Indoor dryer vent bucket Chris G HVAC 3 08-02-2006 06:28 PM
removing old wallpaper daworz Drywall 5 01-26-2006 01:59 PM
Removing stain from a french door or replace? Mike F Painting & Finish Work 6 03-22-2004 10:46 PM
