Helical Piers
Old 08-03-2008, 07:08 PM   #1
It's all about the Avatar
woodmagman's Avatar
Trade: I have no face!
Helical Piers
Is anyone familar with the use of helical piles for underpinning existing footings in northern climates with clay sole conditions?
woodmagman is offline
Old 08-03-2008, 11:43 PM   #2
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Re: Helical Piers
I'm a G.C. in the Bay area. Also, a cert. welder, x pile Buck. 47 Years in the trade. They,re used a lot in clay. Chance is one Co. My friend gets his Fabbed in Canada. 4" heavy wall pipe,their Galvanizing is much heavier, than here in the states,and cheaper. There is a foot pedal and Hydraulic Guage next to it. When You reach so many kips,You're getting good refusal. You epoxy bolt Your
lifting iron and screw up to level again. I am paying $1.00 for mild steel ,just bought a ton of channel Iron. Helicals have to be spendy now.I raised one whole side of our slab home 5 years ago Two Struct. Engineers I,work with said I couldn.t do a slab on grade,I did , They're believers now! We've used them a lot. Much cheaper than re-bar piers. No dirt displaced. Go to_______
www.abchancehelicalpiersystems.com www.peirtech.com
www.helicalpeirsystems.com Where do You live? Drift
Driftwood is offline
Old 08-04-2008, 12:23 AM   #3
Alwaysconfusd11's Avatar
Re: Helical Piers
There is someone on the forums that does Helicals in North Jersey. Try and do a search he has a couple threads about them.
Alwaysconfusd11 is offline
Old 08-04-2008, 06:36 PM   #4
Nac's Avatar
Trade: Concrete, masonry & excavation
Re: Helical Piers
Where are you located? I have done some helical work it all depends on the soil conditions. Do you have boreings? What are you trying to do? How much load?
Nac is offline
Old 08-05-2008, 10:02 AM   #5
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Red face
Re: Helical Piers
You're very welcome WOOD. Any more info I'll jump right on !
Old 08-09-2008, 05:26 PM   #6
woodmagman's Avatar
Re: Helical Piers
Got busy, what can I say!
Going against the odds and doing it for yourself differs the reponsiblity onto yourself. It is always nice to have a qualified stamp on it when putting someone elses house at risk.
Old 08-20-2008, 12:30 AM   #7
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Re: Helical Piers
My own home project, and others we do , are all drawn up by struct. Eng.
Permited and inspected. I'm also a cert. welder.
I know You don't have these skills. Hire a pro Like Me in Your area. Good luck
Old 08-24-2008, 10:46 AM   #8
woodmagman's Avatar
Re: Helical Piers
Are you making your own piers? And no I am not a welder other then doing minor repair to our equiptment. Your thought is that I would need to have a welder on staff for this type of pier. Everything I have looked at is pre-drilled and bolted.
what did you use to put the pier into ground, was it hand held or run from a boom on a skid steer. My thought is to find something hand held that can be powered by our CAT excavator. I have a concrete saw for cutting in windows and doors on concrete foundations and would like to find something that would allow me to use a hand held in crawl spaces and when we can not get the excavator close enough to run something from a boom mounted unit. I have a secondary that runs the thumb on the bucket, when the auger is attached or the concrete saw, I just secure the thumb and bypass the hydraulics.
Old 08-11-2009, 03:27 PM   #9
Joe Nimens
jnimens's Avatar
Trade: Helical Foundations, piles, tiebacks
Re: Helical Piers
This is very common practice for us. It's easy to confirm and or test load bearing capacity and very quick to install. Joe Nimens
jnimens is offline
Old 08-11-2009, 05:03 PM   #10
General Contractor
MacRoadie's Avatar
Trade: General Building Contractor
Re: Helical Piers
We've done quite a few, but all in Southern Cal on slab-on-grade foundation systems. We use the Chance Anchor system as it's all pre-fabricated and available out of the catalog. Piers are driven to the specified depth using either a BobCat with a power take-off outside, or a hand auger drill inside. Fabulous for re-leveling too.
They also work real well as tie-backs for retaining walls or as soil nails.
MacRoadie is offline
Old 08-12-2009, 12:58 PM   #11
Joe Nimens
jnimens's Avatar
Re: Helical Piers
Would you be interested in a less expensive way to get helicals into the ground? As fast or faster.
jnimens is offline
Old 12-31-2010, 09:41 AM   #12
Nac's Avatar
Re: Helical Piers
Sure how?
Nac is offline
Old 01-04-2011, 09:57 PM   #13
ConstSvcs's Avatar
Trade: New home and remodeling
Re: Helical Piers
Faster is not better when installing helicals..........
http://www.youtube.com/watch?v=5StJtqtez8g
I'm sure Nac being another installer .....would also agree
ConstSvcs is offline
Old 01-05-2011, 06:54 PM   #14
Nac's Avatar
Re: Helical Piers
going to fast and you will get augering effect. I want to know his faster cheaper way.
Nac is offline
Old 01-05-2011, 07:01 PM   #15
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
Re: Helical Piers
He hasn't logged in over a year. I'll bet you dollars to doughnuts you don't get your answer.
JustaFramer is offline
Underpinning / HELICAL OR RESISTANCE PIERS Brett@ ECP Excavation & Site Work 0 07-21-2008 11:30 AM
Helical Pile Job Nac Excavation & Site Work Picture Post 11 07-11-2008 05:57 AM
washing piers boman47k Pressure Washing 3 05-20-2008 04:42 PM
washing piers? boman47k Pressure Washing 3 04-21-2008 07:16 PM
Helical Pier Foundation Systems go do it General Discussion 5 02-24-2008 06:36 PM
