Hard Facing
What do you do to prolong life of wear parts?
Do you build up by welding hard facing on edges? I see some really cover everything? Do you add extra wear plates? Do you rotate edges and teeth?
Nick "Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein |
Vagitarian
Re: Hard Facing
We hard face our excavator buckets. It really doesn't last too long here because of all of the rocks. We had to hardface the shanks our our 315 bucket and then grind them to help the bucket teeth fit tighter.
Re: Hard Facing
we run all gummer buckets, so whenever we put on a new edge, we hard surface it. we also hard surface the spikes on our sheepsfoot. believe it or not, took a whole roll of wire to do the pads on the sheepsfoot
someday, i'll be as patient as Nick. |
Excavating Contractor
Trade: Excavating
Re: Hard Facing
Dayexco,
What is a gummer bucket. Never heard of it. |
Re: Hard Facing
just like grandpa, no teeth!
Trade: Excavating
Re: Hard Facing Ok Thanks
Re: Hard Facing
ha....never heard it refered to as a "gummer" but guess it says what it means!!! At my uncles Co. All the "gummer" buckets for our excavators have cutting edges made by a company that are bent to the shape of our sand buckets. Very thick steel that is hardened and they usually last about a season or two. Small tractor backhoe buckets are beefed up by replacing the leading edge of the sides with cutting edge steel, and a thicker cutting edge is welded in place of the factory (john deere) cutting edge/shank section.
| Hard Water, Should I Use Pex? | mikeybobo | Plumbing | 6 | 03-02-2007 10:10 AM |
| Installing hard wood on walls? | boo | Flooring | 12 | 01-12-2007 08:57 PM |
| Ideas For Cutting Hard Costs. | wackman | General Discussion | 18 | 11-22-2006 02:53 PM |
| Hard Times or Hard Up?? | Debookkeeper | Off Topic (Non Trade) | 13 | 08-29-2006 07:42 PM |
| Exterior hard drive for back up. | Mike Finley | Technology | 5 | 07-24-2006 05:51 AM |
