Trade: custom home building
Groundwater Level
we've had a bit of moisture here lately.
I have formed up a slab-on-grade building and poured the footings, waiting for to pour the slab. There is an attached garage on this building and I put a mechanic's pit in there about 5' deep, maybe 4' wide by 16' long. It is concrete block with a concrete floor. It was a bit moist down there when I dug it, so I put in a sump pump pit. Now for the question. The water level in the pit is 2 1/2 blocks (20") below the ground surface. In other words, if it were a bit longer and not full of dead animals, I could quite handily be swimming laps in it. What does this say about the surrounding area. Since this hole is at grade and the water is 20" below the ground surface, what hope should I hold for digging basements in this area? Obviously, this water can be pumped out, but what basement wall can withstand the hydraulic force of being submerged in water? I'm afraid it will either cave in or pop up like a poseidon missile. |
Vagitarian
Re: Groundwater Level
Is it only ground water and no rain water ?? With a proper footing drain system a little extra stone around the walls, I would have no problems with backfilling a foundation like this.
Some rainfall has contributed to the water level in the pit. And ultimately it is all caused by rainfall. But the rainfall is not being funneled into the pit. The area is slightly higher than the surrounding area, in fact. Other than a series of canals to help circulate the water, I'm afraid that a basement in this area would be like standing in a bucket. Unless you let the bucket fill up with water, it will eventually be crushed or pop up out of the water when you get out of it.
do this if you are concerned http://en.wikipedia.org/wiki/French_drain
#5 | |
dude abides.
Trade: commercial excavation, sitework, and utilities
Re: Groundwater LevelQuote:
| concrete block installed out of level | pawlooch | Masonry | 10 | 05-04-2008 11:41 AM |
| Level decks | XanadooLTD | Decks & Fencing | 22 | 04-26-2008 12:25 AM |
| Framing Roof Joists for Addition when top Plate is not Level | personalt | Framing | 3 | 07-20-2007 06:52 AM |
| level decks on the top floors | adman1900 | Carpentry | 1 | 11-11-2006 11:20 AM |
