Grading Problem And Solution Needed, Water Can't Escape...
Old 05-03-2007, 12:53 PM   #1
Little's Avatar
Trade: Commercial Construction
Send a message via AIM to Little
I'm regrading a friends backyard as the property currently slopes towards the house and keeps flooding the basement. Heres' the problem, all the houses surrounding her property including her own all slope the the rear corner of her property and there is no way for me to get the water off the property. Also, we are only a mile from the ocean so there is always a ground water problem. I'm goin to regrade the lot so that the water will seep in across the entire property instead of the one corner, but at the same time give positive pitch away from the house. Is there any way to get the water to drain at the rear of the property using maybe a pipe installed vertically below the water table, filled with stone, fabric over it and capped with soil??
Commercial Construction, Central Jersey
Little is offline
Old 05-03-2007, 08:20 PM   #2
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
Re: Grading Problem And Solution Needed, Water Can't Escape...
Install a catch basin in the back and pipe it to the front.
rino1494 is online now
Old 05-03-2007, 08:43 PM   #3
Little's Avatar
Rino,
No where to pipe it to up front. I was hoping there was some catch basin or something close but nothing, closest inlet is about 200 feet down the street.
Little is offline
Old 05-03-2007, 08:48 PM   #4
Vagitarian
rino1494's Avatar
You said that you want to install a french drain below the water table with fabric and stone. If there is no way to run a pipe out the front, then how are you going to do this ??
Old 05-03-2007, 08:51 PM   #5
Little's Avatar
This was just a few ideas from guys that swear it works. They said the water will gather to the low point at the back of the yard, go down the vertical pipe through the stone and just flow out with the water at the water table, i'm very skeptical. This weekend i'm gonna regrade the yard pretty level and even and see what happens after the rain, if it doesn't help, i could give it a try.
Little is offline
Old 05-03-2007, 08:54 PM   #6
Vagitarian
rino1494's Avatar
I understand what they are saying and it could work for moderate rains. Depending on how high the water table it, maybe you could put in a underground barrel with holes and surrounded by stone. Surface water would gather in the pit and seep into the ground.
Old 05-03-2007, 11:46 PM   #7
PipeGuy's Avatar
Trade: underground
Provided the water table remains below ground level, and the soil is adequately permeable, than you can in fact relieve surface water to the water table. It'd be no different than allowing surface water to drain into a well.
It's not clear to me why you'd want to cap/cover the thing. Once it filled with dirt or debris it would be useless.
Not knowing how deep your talking about digging to reach the groundwater table it's kind of hard to offer specific suggestions. A seven foot deep fix is a lot different than 12 or 14 foot deep solution.
PipeGuy is offline
Old 05-04-2007, 08:38 AM   #8
Little's Avatar
I can reach the water table at 3 1/2-4 feet. I found a 6 foot cut length of 18" HDPE in our yard this morning that i could use. I was thinking of putting filter fabric over the top of the pipe maybe 6" below the ground surface, then capping with like a few inches of really sandy topsoil to the top.
Little is offline
Old 05-04-2007, 09:48 AM   #9
MC Excavating's Avatar
Trade: Excavating, Grading, and Demolition.
What about a catch basin in the rear and sump pump it to the curb in front? We do this all the time in Pasadena, CA. Huge flat lots with no fall to the curb.
MC Excavating is offline
Old 05-04-2007, 01:19 PM   #10
PipeGuy's Avatar
Trade: underground
IMO, relying on the permeability of the soil above the buried pipe to sufficiently convey surface water down into the pipe is an "iffy" proposition. If your only talking about 3 to 4' deep I'd install something with no bottom in it and a grate at grade. Home Depot probably has something made of some kind of plastic or polycarbonate you can make work.
Dig down to 6 to 12 inches below the water table, dump in 6 inches of gravel, set the the pipe or bottomless catch basin on the gravel, put another foot or so of gravel around it, backfill, cut it off to grade and install the grate.
You might even consider adding a 3 or 4 inch layer of sand in the pipe once its in place. Then the owner can periodically remove the top layer that will eventually choke up (the "schmutzdecke" as germans refer to it) and replace it with clean sand. That'll keep the gravel from choking up with dirt and debris over time.
PipeGuy is offline
Old 05-04-2007, 02:25 PM   #11
Little's Avatar
Sounds good brother, i'll run that by them, utilizing the grate.
Little is offline
Old 05-04-2007, 05:30 PM   #12
Vagitarian
rino1494's Avatar
Not in a area where there is frost.
Old 05-15-2007, 03:45 PM   #13
Little's Avatar
Well we got our first few rains since i've regraded the lot so its fairly level but pitches from the house and all looks great. No more water the addition. Now just gonna york rake it and throw down some fast grow and i'm done.
Little is offline
